0015007 | ParaView | (No Category) | public | 2014-09-22 06:17 | 2015-06-02 18:54 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0015007: Problem with the Magnitude calculation for a low values | ||||||||
Description | Open attached file RES_DEPL_0_0.vtu For the field RES_DEPL, the 3 components DX, DY and DZ are well filled with values but the magnitude is not computed correctly for all the cells. This can be seen by coloring the mesh according to each of these components (DX, DY, DZ, Magnitude). The RES_DEPL_Magnituge.png picture demostrates the problem. Note that the values are particularly low for DX and DY ~ 1e-17 in average, up to 1e-39 in some cases. | ||||||||
Project | ParaViS | ||||||||
Topic Name | 0015007_fix_color_range_length | ||||||||
Attached Files | RES_DEPL_0_0.vtu [^] (1,892,422 bytes) 2014-09-22 06:17 RES_DEPL_Magnituge.png [^] (33,894 bytes) 2014-09-22 06:18 | ||||||||
(0034006) Tristan Coulange (developer) 2014-12-23 08:33 |
http://review.source.kitware.com/#/c/18442/ [^] Bug 0015007: Fix color range length Change-Id: Ibc2ed6d0281036697c4cf5f59c56e849200b9cd2 |
(0034223) Tristan Coulange (developer) 2015-02-17 12:20 |
The commit was approved and merged into next. |
(0034330) Tristan Coulange (developer) 2015-03-27 04:45 |
The change broke some tests, so it was reverted and a new change is being reviewed on gitlab: https://gitlab.kitware.com/paraview/paraview/merge_requests/20#note_8372 [^] |
(0034358) Tristan Coulange (developer) 2015-04-13 03:30 |
The change is now merged into master. |
(0034443) Alan Scott (manager) 2015-06-02 18:54 |
This appears to be fixed. Tested with reporters test set. Tested Linux, master, remote server. |
2014-09-22 06:17 | Vadim SANDLER | New Issue | |
2014-09-22 06:17 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-09-22 06:17 | Vadim SANDLER | File Added: RES_DEPL_0_0.vtu | |
2014-09-22 06:18 | Vadim SANDLER | File Added: RES_DEPL_Magnituge.png | |
2014-12-16 10:33 | Tristan Coulange | Status | backlog => active development |
2014-12-23 08:33 | Tristan Coulange | Note Added: 0034006 | |
2015-02-17 12:20 | Tristan Coulange | Note Added: 0034223 | |
2015-02-17 12:20 | Tristan Coulange | Topic Name | => 0015007_fix_color_range_length |
2015-02-17 12:20 | Tristan Coulange | Status | active development => gatekeeper review |
2015-02-18 02:58 | Tristan Coulange | Status | gatekeeper review => active development |
2015-03-27 04:45 | Tristan Coulange | Note Added: 0034330 | |
2015-04-13 03:30 | Tristan Coulange | Note Added: 0034358 | |
2015-04-13 03:30 | Tristan Coulange | Status | active development => gatekeeper review |
2015-06-02 08:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-02 08:44 | Utkarsh Ayachit | Resolution | open => fixed |
2015-06-02 18:54 | Alan Scott | Note Added: 0034443 | |
2015-06-02 18:54 | Alan Scott | Status | customer review => closed |
