0015009 | ParaView | (No Category) | public | 2014-09-23 03:58 | 2014-12-04 10:32 | ||||
Reporter | Vadim SANDLER | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0015009: Naming conflict with gtk package | ||||||||
Description | In Paraview 4.1, there is a python module called gtk: [PARAVIEW_INSTALL_DIR]/lib/paraview-4.1/site-packages/vtk/gtk Problem is that this is also the name of standard python package. Thus, any software using the gtk module may find the ParaView module instead of the standard one. Is it possible to rename the gtk package in the Paraview to avoid naming conflict? | ||||||||
Project | ParaViS | ||||||||
Type | usability | ||||||||
(0033882) Joachim Pouderoux (developer) 2014-12-03 10:04 |
Could'nt you import it as "from vtk import gtk", or "import vtk.gtk as gtk" ? It's under the vtk package, which is equivalent to namespace. We don't think it makes sense to rename a package to support "from vtk import *; import gtk" use-case which is bad style anyways. |
(0033894) Vadim SANDLER (reporter) 2014-12-04 05:33 |
OK, this issue can be closed. |
2014-09-23 03:58 | Vadim SANDLER | New Issue | |
2014-09-23 03:58 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-12-03 10:04 | Joachim Pouderoux | Note Added: 0033882 | |
2014-12-03 10:16 | Joachim Pouderoux | Status | backlog => active development |
2014-12-04 05:33 | Vadim SANDLER | Note Added: 0033894 | |
2014-12-04 06:28 | Joachim Pouderoux | Assigned To | Tristan Coulange => Utkarsh Ayachit |
2014-12-04 10:32 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-12-04 10:32 | Utkarsh Ayachit | Resolution | open => no change required |
2014-12-04 10:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-04 10:32 | Utkarsh Ayachit | Status | customer review => closed |
