0015022 | ParaView | (No Category) | public | 2014-10-01 06:44 | 2015-06-04 21:16 | ||||
Reporter | Jean M. Favre | ||||||||
Assigned To | David C. Lonie | ||||||||
Product Version | 4.2 | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015022: ExtractSubset broken in parallel | ||||||||
Description | read a partitioned structured grid with 2 pvserver processes: ExtractSubset will return some bogus (infinite numbers) coordinates and the data is not visible. brickpvtr = XMLPartitionedRectilinearGridReader(FileName=['/tmp/brick.pvtr']) brickpvtrDisplay = Show(brickpvtr) extractSubset1 = ExtractSubset(Input=brickpvtr) extractSubset1.VOI = [0, 13, 0, 7, 0, 3] extractSubset1Display = Show(extractSubset1) | ||||||||
Project | TBD | ||||||||
Topic Name | 15022_fix_extract_subset | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0033865) Jean M. Favre (reporter) 2014-12-01 03:26 |
I submitted a new python test. I start paraview, get a parallel server. get a python shell, runscript, load file rectGrid_par41.py, and Extract a Subset. Works well in 4.1, does not work in 4.2. It crashes the server, or dumps the following errors: *** Error in `/home/local/apps/PV/4.2/lib/paraview-4.2/pvserver': free(): invalid next size (fast): 0x00000000040b3c70 *** *** Error in `/home/local/apps/PV/4.2/lib/paraview-4.2/pvserver': corrupted double-linked list: 0x00000000040b3c60 ** Jean Favre |
(0033946) David C. Lonie (developer) 2014-12-12 15:26 |
Just to update -- this branch fixes the issue from the VTK side of things: http://review.source.kitware.com/#/t/5152/ [^] Once that's merged into VTK's master branch, I'll enable the parallel filters in ParaView and push this issue to gatekeeper review. |
(0033985) David C. Lonie (developer) 2014-12-18 11:50 |
I've pushed the branch 15022_fix_extract_subset to stage, which brings in the VTK fixes and updates ParaView to use the proper filters. This can't be merged until the VTK topic goes in, but I wanted to leave this fix ready-to-go in case we decide to release ParaView before I return from vacation. |
(0034013) Utkarsh Ayachit (administrator) 2014-12-24 09:15 |
commit b5af90e3b3d499661b8da2237073fa0730eff6bc Author: David C. Lonie <david.lonie@kitware.com> Date: Thu Dec 18 11:46:02 2014 -0500 Use the parallel extract VOI filters in the metafilter. Change-Id: If3f6463ca50d5a5bf137009780f376c0fd74577e commit f49a508bc47dc8ff292bd4317513ecbfa030c42a Author: David C. Lonie <david.lonie@kitware.com> Date: Thu Dec 18 11:45:25 2014 -0500 Bump VTK for extent fixes. Change-Id: Ieb5c5d8060ca9aee2a15bf599ff0ce5d96835fca |
(0034023) Utkarsh Ayachit (administrator) 2015-01-08 08:01 |
Topics merged into master (v4.3.0-RC1-28-gca67a44): (VTK) 15022_fix_extract_subset (VTK) adios-update cgns_plugin_fixes pv-interactor-auto-render-optional (VTK) python-calc-15125 render_on_settings_change return-codes-for-help-and-version server_without_mpi (VTK) update-vtk-20150106 |
(0034509) Alan Scott (manager) 2015-06-04 21:16 |
Old bug in customer review. Closing. |
2014-10-01 06:44 | Jean M. Favre | New Issue | |
2014-10-01 06:44 | Jean M. Favre | File Added: bricks.tar | |
2014-11-20 09:14 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
2014-12-01 03:22 | Jean M. Favre | File Added: rectGrid_par41.py | |
2014-12-01 03:26 | Jean M. Favre | Note Added: 0033865 | |
2014-12-08 12:11 | David C. Lonie | Status | backlog => active development |
2014-12-12 15:26 | David C. Lonie | Note Added: 0033946 | |
2014-12-18 11:50 | David C. Lonie | Note Added: 0033985 | |
2014-12-24 09:15 | Utkarsh Ayachit | Topic Name | => 15022_fix_extract_subset |
2014-12-24 09:15 | Utkarsh Ayachit | Note Added: 0034013 | |
2014-12-24 09:15 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-12-24 09:15 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-12-24 09:15 | Utkarsh Ayachit | Resolution | open => fixed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-08 08:01 | Utkarsh Ayachit | Fixed in Version | 4.3 => git-master |
2015-01-08 08:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-01-08 08:01 | Utkarsh Ayachit | Note Added: 0034023 | |
2015-01-11 09:25 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-06-04 21:16 | Alan Scott | Note Added: 0034509 | |
2015-06-04 21:16 | Alan Scott | Status | customer review => closed |
