0015044 | ParaView | (No Category) | public | 2014-10-10 14:38 | 2015-01-02 10:45 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015044: Representation and HiddenLinesRemoval plugin examples do not work | ||||||||
Description | Email from paraview email list from B.W.H. van Beest <bwvb@xs4all.nl>: I think there is a bug in the plugin example in ../ParaView/Examples/Plugin/Representation (Paraview 4.2) As given, loading the plugin manually, and then creating a new source (e.g. Box) causes Paraview to crash with the error message: > ERROR: In > /usr/local/git/ParaView/ParaViewCore/ServerImplementation/Core/vtkSIProxyDefinitionManager.cxx, > line 565 > vtkSIProxyDefinitionManager (0x265ebb0): No proxy that matches: > group=representations and proxy=SurfaceRepresentationBase were found. > > > ERROR: In > /usr/local/git/ParaView/ParaViewCore/ServerImplementation/Core/vtkSIProxyDefinitionManager.cxx, > line 989 > vtkSIProxyDefinitionManager (0x265ebb0): Failed to locate base proxy > definition (representations, SurfaceRepresentationBase). Aborting for > debugging purposes. > > > Abort The error seems to be in the file Representation.xml, where the attribute base_proxyname is set to "SurfaceRepresentationBase", which should be "SurfaceRepresentation" according to the documentation in http://www.paraview.org/Wiki/ParaView/Plugin_HowTo#Adding_new_Representations_for_3D_View_using_Plugins_.2A_new_in_version_3.7 [^] When I make the change, recompile the plugin and load in into Paraview, there is no longer the above crash when I create a new Box, and the representation "Special Mapper" feautures in the Representationnn combobox. > [243] Representation> diff Representation.xml.org Representation.xml > 7c7 > < base_proxyname="SurfaceRepresentationBase"> > --- > > base_proxyname="SurfaceRepresentation"> | ||||||||
Project | TBD | ||||||||
Topic Name | 15044_update_example_plugins | ||||||||
(0033651) Utkarsh Ayachit (administrator) 2014-10-15 10:08 |
Topics merged into master: 15025_fix_annotations 15035_reverse_connections_dsrs 15043_add_qmake_variable_back 15044_update_example_plugins cmake-cmp0053-warnings live-breakpoint pv-plot-bar-lut visible_range |
(0033767) Alan Scott (manager) 2014-11-06 19:26 |
Trusting this is fixed. Closing. |
2014-10-10 14:38 | Cory Quammen | New Issue | |
2014-10-10 14:38 | Cory Quammen | Assigned To | => Cory Quammen |
2014-10-10 21:18 | Cory Quammen | Topic Name | => 15044_update_example_plugins |
2014-10-10 21:18 | Cory Quammen | Status | backlog => gatekeeper review |
2014-10-10 21:18 | Cory Quammen | Fixed in Version | => 4.2.1 |
2014-10-10 21:18 | Cory Quammen | Resolution | open => fixed |
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | 4.2.1 => git-master |
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033651 | |
2014-11-06 19:26 | Alan Scott | Note Added: 0033767 | |
2014-11-06 19:26 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
