0015048 | ParaView | (No Category) | public | 2014-10-14 18:44 | 2015-01-11 08:14 | ||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Priority | immediate | Severity | major | Reproducibility | have not tried | ||||
Product Version | 4.2 | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0015048: Find data, Max, fails for Windows | ||||||||
Description | Find data, Max, fails for windows. To replicate: * Download 64 bit Windows .exe 4.2.0 install from Kitware website. * Load can.exo. All vars on. Apply. * Find Data dialog. Find Cells From can.ex2. Variable: EQPS. "is max" * Run Selection Query. Fails. My guess is numpy isn't installed. Traceback (most recent call last): File "<string>", line 8, in <module> File "<string>", line 5, in vtkPythonExtractSelection_RequestData File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\extract_selection.py", line 111, in execute output.FieldData.append(nonzero_indices, "vtkSelectedIds"); File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 596, in append ds.GetAttributes(self.Association).append(array, name) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 535, in append arr = numpyTovtkDataArray(copy, name) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 119, in numpyTovtkDataArray vtkarray = numpy_support.numpy_to_vtk(array) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 141, in numpy_to_vtk result_array = create_vtk_array(vtk_typecode) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 97, in create_vtk_array return vtk.vtkDataArray.CreateDataArray(vtk_arr_type) TypeError: CreateDataArray argument 1: an integer is required | ||||||||
Project | Sandia | ||||||||
Topic Name | update-vtk-20141114 | ||||||||
(0033706) Utkarsh Ayachit (administrator) 2014-11-04 12:10 |
commit 519b6803c6506fefc565e608f817151f991c2846 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 4 12:08:10 2014 -0500 Added a test for BUG 0015048. Change-Id: Ib2c1c8b34be34f42578780812b5a9bb1b333416a |
(0033722) Utkarsh Ayachit (administrator) 2014-11-05 08:11 |
SUMMARY --------------------------------------------- Topics merged into master: 0015060_fix_temporalshift_issue 15059_fix_time_comments 15100_fix_color_map_editor_size python_syntax_highlighting_bugs test_max (VTK) vtk_master_20141104 |
(0033782) Utkarsh Ayachit (administrator) 2014-11-06 22:26 |
Verified with the following Windows binaries: 64bit : version 4.2.0-75-g45e7d72 -- success! 32bit : version 4.2.0-75-g45e7d72 -- failure!!!! Traceback (most recent call last): File "<string>", line 8, in <module> File "<string>", line 5, in vtkPythonExtractSelection_RequestData File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\paraview\extract_selection.py", line 111, in execute output.FieldData.append(nonzero_indices, "vtkSelectedIds"); File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 596, in append ds.GetAttributes(self.Association).append(array, name) File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 535, in append arr = numpyTovtkDataArray(copy, name) File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 119, in numpyTovtkDataArray vtkarray = numpy_support.numpy_to_vtk(array) File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 144, in numpy_to_vtk vtk_typecode = get_vtk_array_type(z.dtype) File "C:\Users\utkarsh\Downloads\ParaView-4.2.0-Windows-32bit\ParaView-4.2.0-Windows-32bit\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 71, in get_vtk_array_type 'Could not find a suitable VTK type for %s' % (str(numpy_array_type)) TypeError: Could not find a suitable VTK type for int32 |
(0033783) Utkarsh Ayachit (administrator) 2014-11-06 22:26 |
Windows 32 bit has some issue. |
(0033809) Ben Boeckel (Kitware) (developer) 2014-11-14 11:12 |
VTK branch: http://review.source.kitware.com/#/t/4948/ [^] Now merged into ParaView next's VTK through update-vtk-20141114. |
(0033818) Utkarsh Ayachit (administrator) 2014-11-15 09:57 |
Topics merged into master (v4.2.0-133-g7e996c8) 0015121_fix_ambient_diffuse 14835_fix_log_scale_for_coloring (VTK) 15101_fix_particlepath 15126_fix_properties_panel 15128_fix_output_window_on_Windows (VTK) adios-buffer-resizing cmake-warnings-20140922 fix-COPYONLY-usage osx-deprecation-warnings remove-else-and-endfoo-cmake-args (VTK) update-vtk-20141114 |
(0033819) Utkarsh Ayachit (administrator) 2014-11-15 09:57 |
moving to gatekeeper review till we test the generated binaries. |
(0033861) Utkarsh Ayachit (administrator) 2014-11-27 11:39 |
Topics merged into master (v4.2.0-153-g044be9b) 0015141_add_rotation_factor 0015144_subticks_marks_deactivation 0015146_add_SelectPoints_function_in_pvsimple 15137_fix_label_format 15148_ADIOS_require_MPI (VTK) kdtree-repr qtEvent_player_fix (VTK) update-hdf5 (VTK) vtk_20141122 |
(0033877) Alan Scott (manager) 2014-12-02 16:32 |
Works perfectly. Tested Kitware Windows 32 bit download, nightly, local server. Followed directions on bug. |
2014-10-14 18:44 | Alan Scott | New Issue | |
2014-10-14 18:45 | Alan Scott | Priority | normal => immediate |
2014-10-14 18:45 | Alan Scott | Severity | minor => major |
2014-10-14 18:45 | Alan Scott | Target Version | => 4.2.1 |
2014-10-29 17:31 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
2014-11-04 09:50 | Utkarsh Ayachit | Target Version | 4.2.1 => bug_fix |
2014-11-04 12:10 | Utkarsh Ayachit | Topic Name | => test_max |
2014-11-04 12:10 | Utkarsh Ayachit | Note Added: 0033706 | |
2014-11-04 12:10 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-04 12:10 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-11-04 12:10 | Utkarsh Ayachit | Resolution | open => fixed |
2014-11-05 08:10 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-05 08:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-05 08:11 | Utkarsh Ayachit | Note Added: 0033722 | |
2014-11-06 22:26 | Utkarsh Ayachit | Note Added: 0033782 | |
2014-11-06 22:26 | Utkarsh Ayachit | Note Added: 0033783 | |
2014-11-06 22:26 | Utkarsh Ayachit | Status | customer review => todo |
2014-11-14 11:12 | Ben Boeckel (Kitware) | Topic Name | test_max => update-vtk-20141114 |
2014-11-14 11:12 | Ben Boeckel (Kitware) | Note Added: 0033809 | |
2014-11-14 11:12 | Ben Boeckel (Kitware) | Status | todo => gatekeeper review |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2014-11-15 09:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-15 09:57 | Utkarsh Ayachit | Note Added: 0033818 | |
2014-11-15 09:57 | Utkarsh Ayachit | Note Added: 0033819 | |
2014-11-15 09:57 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
2014-11-27 11:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-27 11:39 | Utkarsh Ayachit | Note Added: 0033861 | |
2014-12-02 16:32 | Alan Scott | Note Added: 0033877 | |
2014-12-02 16:32 | Alan Scott | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master ef0e2b56 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 519b6803 |
