0015063 | ParaView | (No Category) | public | 2014-10-22 06:04 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015063: Warning messages in Slice representation - in parallel server mode | ||||||||
Description | Since 4.2, the following warning messages are output when using the Slice representation of the 3D view on an ImageData: Generic Warning: In /..../ParaView/VTK/Common/DataModel/vtkStructuredData.cxx, line 352 Could not get dimensions for extent! Generic Warning: In /..../ParaView/VTK/Common/DataModel/vtkStructuredData.cxx, line 93 Undefined data description! It happens only when the data is hold by a parallel server. | ||||||||
Steps To Reproduce | Start a server: $ mpirun -np 4 ./pvserver Start a client: $ paraview Connect to the server. Create a Wavelet source. Select a Slice representation. Change the slice position in the Display parameters. Warnings messages are written in the Log window. | ||||||||
Tags | VTK | ||||||||
Project | TBD | ||||||||
(0038687) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-22 06:04 | Joachim Pouderoux | New Issue | |
2014-10-22 06:06 | Joachim Pouderoux | Steps to Reproduce Updated | |
2014-12-11 04:09 | Joachim Pouderoux | Tag Attached: VTK | |
2014-12-11 04:10 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-12-11 04:10 | Joachim Pouderoux | Status | backlog => todo |
2014-12-11 04:11 | Joachim Pouderoux | Status | todo => backlog |
2014-12-11 04:11 | Joachim Pouderoux | Assigned To | Joachim Pouderoux => |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038687 | |
