0015074 | ParaView | (No Category) | public | 2014-10-24 15:15 | 2016-08-12 09:59 | ||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.2 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015074: Maximum number of labels (Color Legend) is wrong | ||||||||
Description | The maximum number of labels for the Color Legend is incorrect, from a user's perspective. The maximum number of labels on the right side of the color legend should equal the maximum number of labels. This includes the min and max label. (Users really don't care that min and max aren't minor labels - they just count up the number of labels, and wonder why there are more than the max). Also, please initialize it to 7 - i.e., same as now (5 minor plus min and max). I couldn't find where this count is initialized, but the bulk of the code is in vtkPVScalarBarActor::ConfigureTicks() (and sub funcitons). It is called NumberOfLabels. | ||||||||
Project | Sandia | ||||||||
(0033665) Alan Scott (manager) 2014-10-24 15:16 |
Color legend cleanup. |
(0033729) Utkarsh Ayachit (administrator) 2014-11-05 11:49 |
This is really not easy to do the way things stand. I am going to delay this for later. Let's plan revisiting color legend and cube axes entirely in near future. The way things stand, both these could use some major cleanups/refactoring. |
(0034647) David C. Lonie (developer) 2015-07-02 11:03 |
Just to add: the "maximum number of labels" option disappears with the new vtkAxis-based placement patch, and the number of labels is determined automatically using the same algorithm as the 2D chart axes. |
(0034648) David C. Lonie (developer) 2015-07-02 11:03 |
Should we close this one, since it's no longer relevant with the new implementation? |
(0034652) Utkarsh Ayachit (administrator) 2015-07-02 11:12 |
We will close with appropriate comments once the change lands. It hasn't, right? |
(0034653) David C. Lonie (developer) 2015-07-02 11:24 |
Nope, it's not merged yet, but here's the PR for reference: https://gitlab.kitware.com/paraview/paraview/merge_requests/183 [^] Sounds good to me. |
(0035724) Alan Scott (manager) 2016-02-11 22:19 |
Has this one landed? Can we move to customer review? |
(0035728) David C. Lonie (developer) 2016-02-12 10:17 |
I don't actually know what happened with this. Either Utkarsh or Cory took over the scalar bar stuff around the time that merge request was made. Let's see what they say. |
(0035735) Utkarsh Ayachit (administrator) 2016-02-13 11:41 |
Cory, can you check if this is still in your implementation? |
(0035736) Cory Quammen (developer) 2016-02-14 23:40 |
Yes, it should work fine. I just verified. |
(0038692) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-24 15:15 | Alan Scott | New Issue | |
2014-10-24 15:16 | Alan Scott | Note Added: 0033665 | |
2014-10-24 15:16 | Alan Scott | Target Version | => 4.3 |
2014-11-04 10:02 | Utkarsh Ayachit | Target Version | 4.3 => bug_fix |
2014-11-05 11:49 | Utkarsh Ayachit | Note Added: 0033729 | |
2014-11-05 11:49 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.3 => 4.4 |
2015-07-02 10:49 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
2015-07-02 11:03 | David C. Lonie | Note Added: 0034647 | |
2015-07-02 11:03 | David C. Lonie | Note Added: 0034648 | |
2015-07-02 11:12 | Utkarsh Ayachit | Note Added: 0034652 | |
2015-07-02 11:24 | David C. Lonie | Note Added: 0034653 | |
2015-07-08 16:36 | Utkarsh Ayachit | Status | backlog => todo |
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
2016-02-11 22:19 | Alan Scott | Note Added: 0035724 | |
2016-02-12 10:17 | David C. Lonie | Note Added: 0035728 | |
2016-02-12 10:17 | David C. Lonie | Assigned To | David C. Lonie => Utkarsh Ayachit |
2016-02-13 11:40 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Cory Quammen |
2016-02-13 11:41 | Utkarsh Ayachit | Note Added: 0035735 | |
2016-02-14 23:40 | Cory Quammen | Note Added: 0035736 | |
2016-03-03 11:13 | Utkarsh Ayachit | Status | todo => backlog |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038692 | |
