0015093 | ParaView | (No Category) | public | 2014-10-30 17:23 | 2015-01-11 08:15 | ||||
Reporter | Jean Hertzberg | ||||||||
Product Version | 4.2 | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015093: Stereo interlace problem | ||||||||
Description | I have not been able to get PV 4.2.0 to work in stereo interlace mode on my Windows 7 64 bit system. Default mode seems to be red-blue, and that works fine, but I get this error on startup when I specify –stereo-type=Interlaced ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\OpenGL\vtkOpenGLCamera.cxx, line 167 vtkOpenGLCamera (000000000B119790): failed after Render 1 OpenGL errors detected 0 : (1282) Invalid operation It continues to run despite this error, but the view generated is mono, not stereo. Alan Scott verified this on his system. On my Windows 8 64bit laptop, PV 4.2.0 will not even start with the -stereo option. PV 4.0.1 starts in interlace mode with no problem on the same system. | ||||||||
Project | TBD | ||||||||
Topic Name | 15093_fix_stereo_issues | ||||||||
(0033679) Utkarsh Ayachit (administrator) 2014-10-31 10:31 |
I can reproduce this on Linux too. |
(0033680) Utkarsh Ayachit (administrator) 2014-10-31 14:33 |
commit 0c9dfba005630fcbb6ce237a800157f0dcb7b60a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Oct 31 14:25:02 2014 -0400 BUG 0015093: Fixed issue with stereo rendering. The problem was that the StereoType set on vtkRenderWindow was incorrect. It ended up picking Crystal Eyes incorrectly. The problem was due to the the "StereoType" property being reset to default by vtkSMParaViewPipelineController. This fixes that. Also added tests to test setting of stereo modes to catch this in future. Change-Id: I20d7227d2059be007b8ff2d1a6abffa349679345 |
(0033701) Utkarsh Ayachit (administrator) 2014-11-04 10:48 |
Topics merged into master: (VTK) update-vtk-20141030 15032_fix_settings_dialog   15076_fix_opacity_mapping_reset    15078_fix_point_sprite    15090_fix_state_loading_issues    15093_fix_stereo_issues    fix-xml-crash-on-close    python_syntax_highlighting_bugs |
(0033762) Alan Scott (manager) 2014-11-06 17:39 |
Initially I missed how to test this. The correct command is ./paraview --stereo --stereo-type=Interlaced. Tested Linux, master, local server. |
2014-10-30 17:23 | Jean Hertzberg | New Issue | |
2014-10-31 10:31 | Utkarsh Ayachit | Note Added: 0033679 | |
2014-10-31 14:33 | Utkarsh Ayachit | Topic Name | => 15093_fix_stereo_issues |
2014-10-31 14:33 | Utkarsh Ayachit | Note Added: 0033680 | |
2014-10-31 14:33 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-10-31 14:33 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-10-31 14:33 | Utkarsh Ayachit | Resolution | open => fixed |
2014-10-31 14:33 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-11-04 10:48 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-04 10:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-04 10:48 | Utkarsh Ayachit | Note Added: 0033701 | |
2014-11-06 17:39 | Alan Scott | Note Added: 0033762 | |
2014-11-06 17:39 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4b501c6a |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 0c9dfba0 |
