0015115 | ParaView | (No Category) | public | 2014-11-07 15:02 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015115: Color editor color mapping import has errors | ||||||||
Description | The color table import code reads in twice, and the second line is named incorrectly. * Master, Linux, local server. * can.exo. All vars on. Apply. * Color by Accl. * Color map editor. (default color map, by the way). * Click on the middle of the three buttons on the horizontal Mapping Data section. Change the color to yellow. Congratulations - you have created a unique, ugly color map. * Save to Preset. (This is right below Choose Preset). Change new preset to deleteMe. * Export this to a file, I chose the name fileDeleteMe. * Now, remove preset deleteMe. * Reset Session. * can.exo. All vars on. Apply. * Color by Accl. * Choose Preset. Import. Import fileDeleteMe. <<Bug - There are two new presets read in, where there should be only one.>> <<Bug - The second preset has a name of Diverging. Obviously wrong.>> | ||||||||
Project | Sandia | ||||||||
(0038708) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-07 15:02 | Alan Scott | New Issue | |
2015-07-08 16:27 | Alan Scott | Target Version | => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038708 | |
