0015126 | ParaView | (No Category) | public | 2014-11-13 10:59 | 2015-01-11 08:15 | ||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015126: Misc separated properties panel issues. | ||||||||
Description | When using separate panels for Display properties (as described here [1]), we had a few issues: * Save/Restore properties buttons don't show up properly. * The Display properties are not updated when switching between multiple sources. [1] http://www.kitware.com/blog/home/post/673 [^] | ||||||||
Project | TBD | ||||||||
Topic Name | 15126_fix_properties_panel | ||||||||
(0033805) Utkarsh Ayachit (administrator) 2014-11-13 11:01 |
commit 6c22d8832872d5f35c0f6ccb67b1666cad1ce00b Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Nov 13 10:59:45 2014 -0500 BUG 0015126: Fix issues with separated properties/display panels. * The save/restore buttons weren't being hidden properly. * The view wasn't saved as a result the display properties weren't being shown correctly. Change-Id: Id5a1eddff034e53b1fe15d85b69de4e105b4c2ca |
(0033815) Utkarsh Ayachit (administrator) 2014-11-15 09:57 |
Topics merged into master (v4.2.0-133-g7e996c8) 0015121_fix_ambient_diffuse 14835_fix_log_scale_for_coloring (VTK) 15101_fix_particlepath 15126_fix_properties_panel 15128_fix_output_window_on_Windows (VTK) adios-buffer-resizing cmake-warnings-20140922 fix-COPYONLY-usage osx-deprecation-warnings remove-else-and-endfoo-cmake-args (VTK) update-vtk-20141114 |
(0033837) Alan Scott (manager) 2014-11-24 21:43 |
Note that you have to close and restart ParaView in order to get the Display tab to appear. |
(0033838) Alan Scott (manager) 2014-11-24 21:45 |
Tested master, linux, remote server. Note that I was seeing some weird artifacts with NX, but believe it is due to the old version of NX installed. |
2014-11-13 10:59 | Utkarsh Ayachit | New Issue | |
2014-11-13 11:01 | Utkarsh Ayachit | Topic Name | => 15126_fix_properties_panel |
2014-11-13 11:01 | Utkarsh Ayachit | Note Added: 0033805 | |
2014-11-13 11:01 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-13 11:01 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-11-13 11:01 | Utkarsh Ayachit | Resolution | open => fixed |
2014-11-13 11:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-11-15 09:56 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-15 09:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-15 09:57 | Utkarsh Ayachit | Note Added: 0033815 | |
2014-11-24 21:43 | Alan Scott | Note Added: 0033837 | |
2014-11-24 21:45 | Alan Scott | Note Added: 0033838 | |
2014-11-24 21:45 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 61f809e5 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6c22d883 |
