0015164 | ParaView | (No Category) | public | 2014-12-01 11:33 | 2016-08-12 09:59 | ||||
Reporter | Ken Sheldon | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015164: XDMF fails to save CELL data | ||||||||
Description | Load the following XDMF file.(This makes a simple 3x4 planar grid) Save the data to a new Xdmf file The saved data contains an Attribute for Cell Centered Values, but the enclpsed DataItem is empty. <Xdmf Version="2.2"> <Domain> <Grid GridType="Uniform"> <Topology TopologyType="2DRectMesh" Dimensions="3 4"/> <Geometry GeometryType="VXVYVZ"> <DataItem Dimensions="1" NumberType="Float" Precision="4" Format="XML">-1</DataItem> <DataItem Dimensions="4" NumberType="Float" Precision="4" Format="XML">1 1.25 1.5 1.75 </DataItem> <DataItem Dimensions="3" NumberType="Float" Precision="4" Format="XML">0 0.25 0.5 </DataItem> </Geometry> <Attribute Name="Cell Centered Values" Active="1" AttributeType="Scalar" Center="Cell"> <DataItem Dimensions="2 3" NumberType="Int" Precision="4" Format="XML"> 1 2 3 4 5 6 </DataItem> </Attribute> <Attribute Name="Node Centered Values" Active="1" AttributeType="Scalar" Center="Node"> <DataItem Dimensions="3 4" NumberType="Int" Precision="4" Format="XML"> 0 1 1 0 1 2 2 1 2 3 3 2 </DataItem> </Attribute> </Grid> </Domain> </Xdmf> | ||||||||
Tags | XDMF | ||||||||
Project | TBD | ||||||||
(0038727) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-12-01 11:33 | Ken Sheldon | New Issue | |
2014-12-01 11:35 | Ken Sheldon | Tag Attached: XDMF | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038727 | |
