0015184 | ParaView | (No Category) | public | 2014-12-05 09:52 | 2015-01-02 10:43 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Tristan Coulange | ||||||||
Priority | high | Severity | crash | Reproducibility | have not tried | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015184: Crash when using Rescale to Visible Data Range | ||||||||
Description | Steps to reproduce: - run paraview/local server - Sources -> Sphere - Color by Normals - Click "Rescale to Visible Data Range" - Crash | ||||||||
Additional Information | Code crashes with backtrace Program received signal SIGSEGV, Segmentation fault. 0x00007ffff2a47495 in vtkHardwareSelector::vtkInternals::ConvertSelection (this=0x1cf1940, fieldassociation=0, dataMap=..., pixelCounts=...) at /home/cory/code/src/ParaView/VTK/Rendering/Core/vtkHardwareSelector.cxx:136 136 ptr[cc] = key.Prop->GetConvertedPickValue(*idIter, fieldassociation); (gdb) bt #0 0x00007ffff2a47495 in vtkHardwareSelector::vtkInternals::ConvertSelection (this=0x1cf1940, fieldassociation=0, dataMap=..., pixelCounts=...) at /home/cory/code/src/ParaView/VTK/Rendering/Core/vtkHardwareSelector.cxx:136 #1 0x00007ffff2a49f65 in vtkHardwareSelector::GenerateSelection (this=0x1cf1840, x1=0, y1=0, x2=1300, y2=686) at /home/cory/code/src/ParaView/VTK/Rendering/Core/vtkHardwareSelector.cxx:751 #2 0x00007ffff38f3f7f in vtkPVHardwareSelector::Select (this=0x1cf1840, region=0x7fffffffc3b0) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVHardwareSelector.cxx:102 #3 0x00007ffff3924310 in vtkPVRenderView::Select (this=0x1ca0990, fieldAssociation=0, region=0x7fffffffc3b0) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx:651 #4 0x00007ffff3924001 in vtkPVRenderView::SelectPoints (this=0x1ca0990, region=0x7fffffffc3b0) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx:603 #5 0x00007fffee4996ee in vtkPVRenderView::SelectPoints (this=0x1ca0990, region0=0, region1=0, region2=1300, region3=686) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.h:261 #6 0x00007fffee494996 in vtkPVRenderViewCommand (arlu=0xbe26e0, ob=0x1ca0990, method=0x41b3c59 "SelectPoints", msg=..., resultStream=...) at Wrapping/ClientServer/vtkPVRenderViewClientServer.cxx:579 #7 0x00007fffed024984 in vtkClientServerInterpreter::CallCommandFunction (this=0xbe26e0, cname=0x7ffff3981512 "vtkPVRenderView", ptr=0x1ca0990, method=0x41b3c59 "SelectPoints", msg=..., result=...) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerStream/vtkClientServerInterpreter.cxx:848 #8 0x00007fffed02316d in vtkClientServerInterpreter::ProcessCommandInvoke (this=0xbe26e0, css=..., midx=0) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerStream/vtkClientServerInterpreter.cxx:437 0000009 0x00007fffed0226c5 in vtkClientServerInterpreter::ProcessOneMessage (this=0xbe26e0, css=..., message=0) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerStream/vtkClientServerInterpreter.cxx:269 #10 0x00007fffed02254f in vtkClientServerInterpreter::ProcessStream (this=0xbe26e0, css=...) at /home/cory/code/src/ParaView/ParaViewCore/ClientServerStream/vtkClientServerInterpreter.cxx:238 0000011 0x00007ffff305b1cb in vtkPVSessionCore::ExecuteStreamInternal (this=0xbe1be0, stream=..., ignore_errors=false) at /home/cory/code/src/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:669 #12 0x00007ffff305afd3 in vtkPVSessionCore::ExecuteStream (this=0xbe1be0, location=21, stream=..., ignore_errors=false) at /home/cory/code/src/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:639 #13 0x00007ffff3057822 in vtkPVSessionBase::ExecuteStream (this=0xbe2650, location=21, stream=..., ignore_errors=false) at /home/cory/code/src/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionBase.cxx:168 #14 0x00007ffff34a1ba6 in vtkSMProxy::ExecuteStream (this=0xb85970, stream=..., ignore_errors=false, location=21) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Core/vtkSMProxy.cxx:2321 #15 0x00007ffff46c2ce4 in vtkSMRenderViewProxy::SelectSurfacePoints (this=0xb85970, region=0x7fffffffce50, selectedRepresentations=0x42fef80, selectionSources=0x40eada0, multiple_selections=true) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMRenderViewProxy.cxx:871 #16 0x00007ffff46c3446 in vtkSMRenderViewProxy::ComputeVisibleScalarRange (this=0xb85970, region=0x7fffffffce50, fieldAssociation=0, scalarName=0x1d9ccc8 "Normals", component=-1, range=0x7fffffffcee0) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMRenderViewProxy.cxx:988 #17 0x00007ffff46c31fe in vtkSMRenderViewProxy::ComputeVisibleScalarRange (this=0xb85970, fieldAssociation=0, scalarName=0x1d9ccc8 "Normals", component=-1, range=0x7fffffffcee0) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMRenderViewProxy.cxx:958 #18 0x00007ffff46bd47d in vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange (this=0x3999f10, view=0xb85970, arrayname=0x1d9ccc8 "Normals", attribute_type=0) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.cxx:406 #19 0x00007ffff46bcef4 in vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange (this=0x3999f10, view=0xb85970) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.cxx:349 #20 0x00007ffff7aecf8e in vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange (proxy=0x3999f10, view=0xb85970) at /home/cory/code/src/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.h:169 #21 0x00007ffff7b2eda6 in pqRescaleVisibleScalarRangeReaction::rescaleVisibleScalarRange (this=0xbbff40) at /home/cory/code/src/ParaView/Qt/ApplicationComponents/pqRescaleVisibleScalarRangeReaction.cxx:79 #22 0x00007ffff7b62156 in pqRescaleVisibleScalarRangeReaction::onTriggered (this=0xbbff40) at Qt/ApplicationComponents/../../../../src/ParaView/Qt/ApplicationComponents/pqRescaleVisibleScalarRangeReaction.h:59 #23 0x00007ffff7b6174c in pqReaction::qt_static_metacall (_o=0xbbff40, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0x7fffffffd210) at Qt/ApplicationComponents/moc_pqReaction.cxx:51 #24 0x00007ffff582887a in QMetaObject::activate (sender=sender@entry=0xbbbe90, m=m@entry=0x7ffff67efde0 <QAction::staticMetaObject>, local_signal_index=local_signal_index@entry=1, argv=argv@entry=0x7fffffffd210) at kernel/qobject.cpp:3539 #25 0x00007ffff5d3fa62 in QAction::triggered (this=this@entry=0xbbbe90, _t1=false) at .moc/release-shared/moc_qaction.cpp:276 #26 0x00007ffff5d41433 in QAction::activate (this=0xbbbe90, event=<optimized out>) at kernel/qaction.cpp:1257 #27 0x00007ffff60f8b02 in QAbstractButtonPrivate::click (this=this@entry=0xbbe750) at widgets/qabstractbutton.cpp:530 #28 0x00007ffff60f8c2c in QAbstractButton::mouseReleaseEvent (this=0xbbe720, e=0x7fffffffd6d0) at widgets/qabstractbutton.cpp:1123 #29 0x00007ffff61afa4a in QToolButton::mouseReleaseEvent (this=<optimized out>, e=<optimized out>) at widgets/qtoolbutton.cpp:723 #30 0x00007ffff5d9550a in QWidget::event (this=0xbbe720, event=0x7fffffffd6d0) at kernel/qwidget.cpp:8376 #31 0x00007ffff5d45e2c in QApplicationPrivate::notify_helper (this=this@entry=0x79b080, receiver=receiver@entry=0xbbe720, e=e@entry=0x7fffffffd6d0) at kernel/qapplication.cpp:4567 #32 0x00007ffff5d4c5dd in QApplication::notify (this=<optimized out>, receiver=0xbbe720, e=0x7fffffffd6d0) at kernel/qapplication.cpp:4110 #33 0x00007ffff58144dd in QCoreApplication::notifyInternal (this=0x7fffffffde70, receiver=receiver@entry=0xbbe720, event=event@entry=0x7fffffffd6d0) at kernel/qcoreapplication.cpp:953 #34 0x00007ffff5d4bd93 in sendEvent (event=<optimized out>, receiver=<optimized out>) at ../../include/QtCore/../../src/corelib/kernel/qcoreapplication.h:231 #35 QApplicationPrivate::sendMouseEvent (receiver=receiver@entry=0xbbe720, event=event@entry=0x7fffffffd6d0, alienWidget=alienWidget@entry=0xbbe720, nativeWidget=nativeWidget@entry=0xbaf200, buttonDown=buttonDown@entry=0x7ffff682b318 <qt_button_down>, lastMouseReceiver=..., spontaneous=spontaneous@entry=true) at kernel/qapplication.cpp:3178 #36 0x00007ffff5dc09cb in QETWidget::translateMouseEvent (this=this@entry=0xbaf200, event=event@entry=0x7fffffffda50) at kernel/qapplication_x11.cpp:4634 #37 0x00007ffff5dc0269 in QApplication::x11ProcessEvent (this=0x7fffffffde70, event=event@entry=0x7fffffffda50) at kernel/qapplication_x11.cpp:3627 #38 0x00007ffff5de7b02 in x11EventSourceDispatch (s=0x798040, callback=0x0, user_data=0x0) at kernel/qguieventdispatcher_glib.cpp:146 #39 0x00007fffeaa6ce04 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 #40 0x00007fffeaa6d048 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 #41 0x00007fffeaa6d0ec in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 #42 0x00007ffff58417a1 in QEventDispatcherGlib::processEvents (this=0x79c170, flags=...) at kernel/qeventdispatcher_glib.cpp:434 #43 0x00007ffff5de7bb6 in QGuiEventDispatcherGlib::processEvents (this=<optimized out>, flags=...) at kernel/qguieventdispatcher_glib.cpp:204 #44 0x00007ffff58130af in QEventLoop::processEvents (this=this@entry=0x7fffffffde20, flags=...) at kernel/qeventloop.cpp:149 #45 0x00007ffff58133a5 in QEventLoop::exec (this=this@entry=0x7fffffffde20, flags=...) at kernel/qeventloop.cpp:204 #46 0x00007ffff5818b79 in QCoreApplication::exec () at kernel/qcoreapplication.cpp:1225 #47 0x00000000004094c4 in main (argc=1, argv=0x7fffffffdf98) at Applications/ParaView/paraview_main.cxx:112 | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0033899) Alan Scott (manager) 2014-12-05 14:29 edited on: 2014-12-05 14:29 |
I just tried using a week old version of master, Linux (hardware and then Mesa rendering), and could not replicate this crash. What operating system was it on? |
(0033901) Cory Quammen (developer) 2014-12-06 10:01 |
The crash occurred on Ubuntu 14.04 run as a VirtualBox guest OS on Win7 64-bit host. I get limited hardware rendering at best on this system, and since the crash is in vtkHardwareSelector, it may be a problem just on my system. Point and cell selection works on this system just fine, though. I tested on the ParaView nightly build for Win7 64-bit from 2014/12/6 and it did not crash. I'll change this to gatekeeper review with no fix. |
(0033902) Cory Quammen (developer) 2014-12-06 10:03 |
This bug may not be related to the rescaling feature tested, but rather the vtkHardwareSelector when run on certain OS's in a virtual machine environment. |
(0033903) Utkarsh Ayachit (administrator) 2014-12-08 08:04 |
Topics merged into master (v4.2.0-231-g445a425): 0015171_camera_front_of_plane_widget 0015172_automatic_annotations (VTK) exodus-15127 fix-log-mark-labels fix-osx-fileinfo fix_pvscalarabar_warning genericio_reader_optimization include-missing-header linking-with-kits-enabled (VTK) map-scalars-14943 pvweb-fix-extract-block-bug pvweb-fix-incorrect-filter-name qt5-find-components |
(0033927) Alan Scott (manager) 2014-12-10 15:22 |
I agree - lets close the bug. It doesn't replicate with steps to reproduce as given. Cory - please reopen or open a new bug with detailed steps if you can reproduce. |
2014-12-05 09:52 | Cory Quammen | New Issue | |
2014-12-05 09:52 | Cory Quammen | Assigned To | => Tristan Coulange |
2014-12-05 09:53 | Cory Quammen | Severity | minor => crash |
2014-12-05 09:53 | Cory Quammen | Additional Information Updated | |
2014-12-05 14:29 | Alan Scott | Note Added: 0033899 | |
2014-12-05 14:29 | Alan Scott | Note Edited: 0033899 | |
2014-12-06 10:01 | Cory Quammen | Note Added: 0033901 | |
2014-12-06 10:03 | Cory Quammen | Note Added: 0033902 | |
2014-12-06 10:03 | Cory Quammen | Status | backlog => gatekeeper review |
2014-12-06 10:03 | Cory Quammen | Resolution | open => unable to reproduce |
2014-12-08 08:03 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-12-08 08:04 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-08 08:04 | Utkarsh Ayachit | Note Added: 0033903 | |
2014-12-10 15:22 | Alan Scott | Note Added: 0033927 | |
2014-12-10 15:22 | Alan Scott | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
