0015216 | ParaView | (No Category) | public | 2014-12-18 17:17 | 2015-08-11 14:40 | ||||
Product Version | 4.2 | ||||||||
Target Version | 4.4 | Fixed in Version | |||||||
Summary | 0015216: CGNS reader is dreadfully slow | ||||||||
Description | The CGNS reader is painfully, reduculiously, dreadfully slow. It takes about 30 seconds to read the header for a toy dataset, and with this dataset the following line gets written out a few hundred times. *** Warning:The file being read is more recent that the CGNS library used *** Figure out what is going on, and fix it. Further, turn off the warning for production builds. File available upon request. File name is aero3d.cgns. | ||||||||
Project | Sandia | ||||||||
Type | performance | ||||||||
(0034304) Alan Scott (manager) 2015-03-13 18:13 |
I have a user that tried to use the CGNS, and found it to be unusable... |
(0034312) Mickael PHILIT (reporter) 2015-03-16 15:17 edited on: 2015-03-16 15:17 |
It would be interesting to try with the CGNS plugin included in the master branch. |
(0034316) Alan Scott (manager) 2015-03-18 15:57 |
I just looked, and couldn't find a CGNS plugin. I looked in 4.3.1 Kitware windows, my own personal Linux 4.3.1 build, my personal Linux build of master, and looked in the Build/ Plugins directory. How do I get the CGNS plugin? Is there a magic CMake switch? |
(0034317) Mickael PHILIT (reporter) 2015-03-18 18:14 |
The cmake switch is off by default. You may want to use the latest/current development master to get a working reader. (Until recently, it was available on the superbuild dashboard) |
(0034695) Utkarsh Ayachit (administrator) 2015-07-08 09:55 |
Folks, the CGNS plugin was merged into ParaView proper a little while ago. See: https://gitlab.kitware.com/paraview/paraview/commit/f011a67942e7ff5a04e1ecbc98427b749fdb5002 [^] So long as you build with CGNS support enabled, ParaView will indeed use the newer CGNS reader that Mickael contributed. |
(0034696) Utkarsh Ayachit (administrator) 2015-07-08 10:05 |
Oh, btw, there's a new flag PARAVIEW_ENABLE_CGNS that you need to turn on to enable CGNS support in ParaView. |
(0034899) Utkarsh Ayachit (administrator) 2015-08-05 21:41 |
Please reopen if the new CGNS implementation is still slow. |
(0034957) Alan Scott (manager) 2015-08-11 14:40 |
Much, much better. Tested Kitware's nightly build from 8/10/2015. Windows. Local server. |
2014-12-18 17:17 | Alan Scott | New Issue | |
2015-03-13 18:13 | Alan Scott | Note Added: 0034304 | |
2015-03-13 18:13 | Alan Scott | Target Version | => 4.4 |
2015-03-16 15:17 | Mickael PHILIT | Note Added: 0034312 | |
2015-03-16 15:17 | Mickael PHILIT | Note Edited: 0034312 | |
2015-03-18 15:57 | Alan Scott | Note Added: 0034316 | |
2015-03-18 18:14 | Mickael PHILIT | Note Added: 0034317 | |
2015-07-08 09:55 | Utkarsh Ayachit | Note Added: 0034695 | |
2015-07-08 10:05 | Utkarsh Ayachit | Note Added: 0034696 | |
2015-07-08 16:36 | Utkarsh Ayachit | Status | backlog => todo |
2015-08-05 21:41 | Utkarsh Ayachit | Note Added: 0034899 | |
2015-08-05 21:41 | Utkarsh Ayachit | Status | todo => customer review |
2015-08-05 21:41 | Utkarsh Ayachit | Resolution | open => fixed |
2015-08-05 21:41 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-08-05 21:41 | Utkarsh Ayachit | Resolution | fixed => no change required |
2015-08-11 14:40 | Alan Scott | Note Added: 0034957 | |
2015-08-11 14:40 | Alan Scott | Status | customer review => closed |
