0015229 | ParaView | (No Category) | public | 2014-12-23 20:23 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015229: Add ability to create groups of elements, nodes, blocks, sidesets, etc | ||||||||
Description | Please add the ability to group elements, nodes, blocks, sidesets, etc. Lets say you have a car. Every part of the car is a separate block. You have a few hundred to a few thousand blocks. The user should have the ability to make all of the blocks of the engine one group, all blocks of the transmission a group. etc. This should be able to be saved somehow, so that the next time user reads the dataset, these blocks still exist. I would say that grouping blocks and sets is much more important than elements and nodes. You should be able to select the groups as we currently can select blocks. You also want to be able to toggle their visibility, opacity, color, etc. A use case would be using bake.exo. You want to group all of the outside walls, all of the outside columns, all of the interior radiators, and the inside test object together. Then, you would have only 4 objects to load, color, etc. which makes much more sense. Ask Utkarsh or me for this dataset. | ||||||||
Additional Information | Move to PV 4.5 if necessary. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0038750) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-12-23 20:23 | Alan Scott | New Issue | |
2014-12-23 20:26 | Alan Scott | Description Updated | |
2014-12-23 20:55 | Alan Scott | Description Updated | |
2014-12-24 18:52 | Alan Scott | Additional Information Updated | |
2014-12-24 18:53 | Alan Scott | Target Version | => 4.4 |
2015-06-29 11:45 | Utkarsh Ayachit | Target Version | 4.4 => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038750 | |
