0015305 | ParaView | (No Category) | public | 2015-02-05 14:27 | 2015-09-06 12:18 | ||||
Reporter | Andy Bauer | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015305: warning from vtkSMEnumerationDomain.cxx with grid with greater than 2^31 points | ||||||||
Description | This problem is reproducible in the GUI with the following: 1) Create a Wavelet with whole extent [0, 1290, 0, 1290, 0, 1290] 2) Hit Apply 3) Create a Gradient of Unstructured Data Set filter A warning pops up with is "Invalid idx: 0" in vtkSMEnumerationDomain.cxx, line 75 of vtkSMFieldDataDomain. | ||||||||
Project | TBD | ||||||||
Topic Name | 15305_fix_client_server_array_information | ||||||||
(0034179) Andy Bauer (developer) 2015-02-06 11:44 |
This issue seems to be independent of the data set as well as the applied filter where a field needs to be chosen in the GUI (e.g. contour filter should also replicate the issue). It appears that if the user selects a different array than the default array in the filter that the filter operation still only happens on the default array. |
(0034180) Utkarsh Ayachit (administrator) 2015-02-06 16:15 |
commit 25eb97ab3d89583709e22b4bad48188bbb6370b6 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 6 16:12:15 2015 -0500 BUG 0015305. vtkPVArrayInformation now handles large number of tuples. NumberOfTuples was simply an int. Which was causing overflow related issues manifesting as the error message report in the BUG 0015305. This fixes that issue. Change-Id: Id27ec88b51bd95d3f62ed5dca4f0bba70842df65 |
(0034184) Utkarsh Ayachit (administrator) 2015-02-07 07:18 |
Topics merged into master (v4.3.1-142-g595cef6): 0015305_fix_large_data_issue cinema_specA_tweaks find_subhalos_of_all fix_potential_jsdoc_issue (VTK) output-window-15297 push_specA_cinema pvweb-create-visualizer-howto-guide pvweb-update-launcher-examples |
(0034265) Utkarsh Ayachit (administrator) 2015-02-20 09:46 |
reopening since it still fails in client-server. |
(0034267) Utkarsh Ayachit (administrator) 2015-02-20 10:17 |
commit 328b70f838cd87337341c34ceec0867beff53622 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 20 10:15:07 2015 -0500 BUG 0015305: Fixes information issue in client-server mode. vtkPVArrayInformation wasn't using the right type for number of tuples when reading the value from the vtkClientServerStream causing the precison loss that commit 25eb97ab fixed for builtin mode. Fixed that. Change-Id: Ic6ae2f7a8b04aaeb76515cf44695ff6770520461 |
(0034272) Utkarsh Ayachit (administrator) 2015-02-23 09:10 |
--------------------------------------------- Topics merged into master (v4.3.1-188-g97826b1): 15305_fix_client_server_array_information cinema_specA_tweaks (VTK) point-gaussian-representation (VTK) pvweb-add-color-editor volume_rendering_opengl2_fixes |
(0034502) Alan Scott (manager) 2015-06-04 18:57 |
Tested master, Linux, remote server. 16 nodes, redsky. |
2015-02-05 14:27 | Andy Bauer | New Issue | |
2015-02-05 14:27 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2015-02-06 11:44 | Andy Bauer | Note Added: 0034179 | |
2015-02-06 16:15 | Utkarsh Ayachit | Topic Name | => 0015305_fix_large_data_issue |
2015-02-06 16:15 | Utkarsh Ayachit | Note Added: 0034180 | |
2015-02-06 16:15 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2015-02-06 16:15 | Utkarsh Ayachit | Fixed in Version | => git-next |
2015-02-06 16:15 | Utkarsh Ayachit | Resolution | open => fixed |
2015-02-07 07:18 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-02-07 07:18 | Utkarsh Ayachit | Note Added: 0034184 | |
2015-02-20 09:46 | Utkarsh Ayachit | Note Added: 0034265 | |
2015-02-20 09:46 | Utkarsh Ayachit | Status | customer review => todo |
2015-02-20 10:17 | Utkarsh Ayachit | Topic Name | 0015305_fix_large_data_issue => 15305_fix_client_server_array_information |
2015-02-20 10:17 | Utkarsh Ayachit | Note Added: 0034267 | |
2015-02-20 10:17 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2015-02-23 09:10 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2015-02-23 09:10 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-02-23 09:10 | Utkarsh Ayachit | Note Added: 0034272 | |
2015-06-04 18:57 | Alan Scott | Note Added: 0034502 | |
2015-06-04 18:57 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
