0015319 | ParaView | (No Category) | public | 2015-02-12 15:02 | 2016-08-12 09:59 | ||||
Product Version | 4.3 | ||||||||
Summary | 0015319: Scalar Bar label position is WRONG! | ||||||||
Description | + Sphere, Apply, + Calculator, Expression= "1", Apply + Color by "Result" + Edit Color Map, + Set color map range to custom range (0, 10). Edit the color legend properties and change the maximum number of labels to 25. Uncheck "Draw Sub Tick Marks", just to keep the legend easy to read. + Change number of table values to 10. You'll get a color legend similar to the one attached. This is wrong! Verify by change the Calculator expression to 0, 1, 2,.... and see what color it produces and what it shows as in the color legend. | ||||||||
Project | Sandia | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0038773) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-02-12 15:02 | Utkarsh Ayachit | New Issue | |
2015-02-12 15:02 | Utkarsh Ayachit | File Added: sample.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038773 | |
