0015326 | ParaView | (No Category) | public | 2015-02-16 10:19 | 2016-08-12 09:59 | ||||
Reporter | fetzer | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 4.2 | ||||||||
Summary | 0015326: Filename when saving data | ||||||||
Description | Hi, when I save data to a file, it always appends a '0' to my filename. I guess it is a bug. Especially the question whether I want to overwrite an existing file is misplaced: if I delete the ending zero in my filename before saving, it will not ask me, but will directly overwrite the existing file. I am using paraview 4.2.0. Best regards, Thomas Noted. Feel free to report a bug on the bug tracker (http://paraview.org/Bug [^]). I am not sure how this could be addressed but let's see. The problem ends up being specific writers can pick filename variants based on the nature of the data they are writing and that information is not available to the UI when it shows the Save Data dialog. Thanks Utkarsh | ||||||||
Project | TBD | ||||||||
(0038775) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-02-16 10:19 | fetzer | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038775 | |
