0015406 | ParaView | (No Category) | public | 2015-04-01 16:59 | 2016-08-12 09:59 | ||||
Reporter | Todd Berendes | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015406: NetCDF reader doesn't apply scale factor to lat/lon for CF compliant files | ||||||||
Description | I'm trying to read swath data from a CF compliant NetCDF file. The lat/lon values are stored as integers with a scale factor of 0.001 that needs to be applied to scale to float/double values. Here is the NetCDF attribute for latitude in my file: int lat(along_track=18158, cross_track=42); :units = "degrees_north"; :comment = "Pixel Latitude [-90:90]"; :scale_factor = 0.001; // double :long_name = "Pixel Latitude"; :standard_name = "latitude"; The reader correctly interprets the lat field as latitude based on the CF attribute "standard_name", but erroneously sets the points in the resulting unstructured grid as their unscaled values. I have noticed that the scale factor is correctly applied to other CF compliant variables just not the latitude and longitude point values. | ||||||||
Project | TBD | ||||||||
(0038797) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-04-01 16:59 | Todd Berendes | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038797 | |
