0015415 | ParaView | (No Category) | public | 2015-04-07 19:28 | 2016-08-12 09:59 | ||||
Summary | 0015415: Ouptut Message window shouldn't pop to front | ||||||||
Description | The output messages window is popping to the front, even if nothing is being shown. Don't pop this window to the front, unless it has something that needs to be shown. The easy way to replicate it is Linux, remote server, software rendered with mesa, master. Open something, volume render. You will get "Missing FBO support: The algorithm may produce visual artifacts" warnings. Mask these warnings in the Filter button, bottom of the window. Now, make ParaView create another of these warnings (flip your dataset to surface, then back to volume rendered). The output window will pop to the top! I am pretty sure this can be replicated with Wavelet, but did not try. The secret will be a debug build, remote server. | ||||||||
Project | Sandia | ||||||||
(0038799) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-04-07 19:28 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038799 | |
