0015436 | ParaView | (No Category) | public | 2015-04-28 03:58 | 2016-08-12 09:59 | ||||
Reporter | mag | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015436: segmentation fault when loading cgns file | ||||||||
Description | I used the nightly build ParaView-4.3.1-476-gfe14b9a-Linux-64bit on Ubuntu 14.10. Paraview starts showing the following warning on console: Unable to load library icui18n "Cannot load library icui18n: (icui18n: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)" Then, when I try to load a cgns file ( e.g. the one attached ) paraview crashes. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | 2d_cube_G1.cgns [^] (2,067,365 bytes) 2015-04-28 03:58 | ||||||||
(0035026) mag (reporter) 2015-08-19 06:41 |
I tested it with the recent nightly build: ParaView-4.3.1-1032-gba5a4bb-Qt4-OpenGL2-Linux-64bit I am not able to load any cgns file since paraview crashes saying "segmantation fault". I tested different files. |
(0035437) Menno Deij (reporter) 2015-11-09 02:44 |
This problem has made it into 4.4.0 release unfortunately. |
(0038808) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-04-28 03:58 | mag | New Issue | |
2015-04-28 03:58 | mag | Assigned To | => Alan Scott |
2015-04-28 03:58 | mag | File Added: 2d_cube_G1.cgns | |
2015-04-28 15:43 | Alan Scott | Assigned To | Alan Scott => |
2015-08-19 06:41 | mag | Note Added: 0035026 | |
2015-11-09 02:44 | Menno Deij | Note Added: 0035437 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038808 | |
