0015467 | ParaView | (No Category) | public | 2015-05-12 11:41 | 2016-08-12 09:59 | ||||
Product Version | 4.3 | ||||||||
Summary | 0015467: Make it easier to create vertex glyphs | ||||||||
Description | A common question on the ParaView mailing list is to be able to see the points of a dataset that have no cells. The answer is to apply the glyph filter using vertex glyphs. The problem is that it is unnecessarily hard and completely counterintuitive to set up the glyph filter for vertex glyphs. First you have to select "2D Glyph" as the Glyph Type (which is itself odd since a vertex is 0D). Then you have to open up the advanced properties, find another property that is confusingly also named Glyph Type, and then finally change that to "Vertex". You should be able to select Vertex directly from the first Glyph Type chooser box. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0038822) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-05-12 11:41 | Ken Moreland | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038822 | |
