0015470 | ParaView | (No Category) | public | 2015-05-15 09:09 | 2015-09-08 13:10 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | David C. Lonie | ||||||||
Product Version | 4.3 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015470: pvd + vtr combo doesn't work in parallel | ||||||||
Description | Steps to reproduce: 1. Run pvserver in parallel (more than a single process) and connect the GUI client 2. Load in zVTR.pvd (attached) 3. Step forward and backward in time a couple of times The extents stay the same but the number of cells decrease in time. This works fine with just using the File Series Reader to read in the vtr files. I suspect it's something with either ghost cells or piece number/number of pieces getting messed up. | ||||||||
Project | ERDC | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||
(0035067) David C. Lonie (developer) 2015-08-26 12:20 |
VTK PR: https://gitlab.kitware.com/vtk/vtk/merge_requests/553 [^] PV PR: https://gitlab.kitware.com/paraview/paraview/merge_requests/313 [^] |
(0035124) Alan Scott (manager) 2015-09-02 14:29 |
I didn't see any increase/decrease in number of cells over time. However, if you look at p(psi), it does change between the two time steps. I believe this shows that the pvd vtr combo is working. |
2015-05-15 09:09 | Andy Bauer | New Issue | |
2015-05-15 09:09 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2015-05-15 09:09 | Andy Bauer | File Added: pvdTests.tar | |
2015-05-17 10:46 | Utkarsh Ayachit | Project | TBD => ERDC |
2015-08-10 12:37 | Utkarsh Ayachit | Status | backlog => todo |
2015-08-10 12:37 | Utkarsh Ayachit | Target Version | => 4.4 |
2015-08-18 10:34 | David C. Lonie | Assigned To | Utkarsh Ayachit => David C. Lonie |
2015-08-18 10:34 | David C. Lonie | Status | todo => active development |
2015-08-26 12:20 | David C. Lonie | Note Added: 0035067 | |
2015-08-31 17:02 | Utkarsh Ayachit | Relationship added | related to 0015679 |
2015-08-31 17:07 | Utkarsh Ayachit | Status | active development => customer review |
2015-08-31 17:07 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-08-31 17:07 | Utkarsh Ayachit | Resolution | open => fixed |
2015-09-02 14:29 | Alan Scott | Note Added: 0035124 | |
2015-09-02 14:29 | Alan Scott | Status | customer review => closed |
2015-09-03 09:41 | Utkarsh Ayachit | Status | closed => customer review |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
2015-09-08 13:10 | Utkarsh Ayachit | Status | customer review => closed |
