0015475 | ParaView | Feature | public | 2015-05-19 03:29 | 2015-09-06 12:18 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015475: Add a periodic filter fonctionnality | ||||||||
Description | A client requested to add a periodic filter fonctionnality. The idea is to be able to create lightweight periodic meshes from existing grids. For each grid, a Multipiece data object is created. It contains the original grid plus periodic version of the grid at different periodic position (for now an angle value). The periodic meshes are very lightweight objects because we use mapped data arrays: data (point coordinates, vectors, tensors) are not copied but transformed on the fly when needed from the original arrays. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0034421) Mathieu Westphal (developer) 2015-05-20 03:17 edited on: 2015-06-03 03:13 |
Merge Request #109 ยท created by Mathieu Westphal: Periodic Filter Adding a periodic filter fonctionnality to paraview, using the new vtkAngularPeriodicFilter and vtkPeriodicFilter. https://gitlab.kitware.com/paraview/paraview/merge_requests/109 [^] [^] |
(0034452) Mathieu Westphal (developer) 2015-06-03 03:17 |
To test this fonctionnality you can use the provided test (AngularPeriodicFilter) or do the following : -Add a box source, apply -Add a Group Dataset, apply -Add a Angular Periodic Filter, select the block in interface, apply |
(0034479) Utkarsh Ayachit (administrator) 2015-06-04 17:27 |
Mathieu, Here are steps to reproduce the parallel failure: + Connect ParaView to a pvserver with at least 2 ranks. + Open can.ex2 + Apply Angular Periodic Filter -- server will segfault. The same segfault can be reproduced using your steps as well. I am using local rendering i.e. remote rendering is disabled -- FYI. |
(0034511) Mathieu Westphal (developer) 2015-06-05 05:40 |
Corrected by: https://gitlab.kitware.com/vtk/vtk/merge_requests/279 [^] Thanks for bug test. |
(0034520) Alan Scott (manager) 2015-06-08 18:48 |
Nice. Tested remote server, Linux, master. Used can.exo (i.e., one file) and z_pinch (eight files). |
2015-05-19 03:29 | Mathieu Westphal | New Issue | |
2015-05-19 03:29 | Mathieu Westphal | Assigned To | => Joachim Pouderoux |
2015-05-20 03:17 | Mathieu Westphal | Note Added: 0034421 | |
2015-05-20 04:25 | Joachim Pouderoux | Description Updated | |
2015-05-27 04:08 | Mathieu Westphal | Assigned To | Joachim Pouderoux => |
2015-05-27 04:09 | Mathieu Westphal | Assigned To | => Joachim Pouderoux |
2015-05-27 04:09 | Joachim Pouderoux | Status | backlog => gatekeeper review |
2015-05-27 04:09 | Joachim Pouderoux | Resolution | open => fixed |
2015-05-27 04:10 | Joachim Pouderoux | Category | (No Category) => Feature |
2015-06-02 08:45 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-02 08:45 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-06-03 03:13 | Mathieu Westphal | Note Edited: 0034421 | |
2015-06-03 03:17 | Mathieu Westphal | Note Added: 0034452 | |
2015-06-04 17:27 | Utkarsh Ayachit | Note Added: 0034479 | |
2015-06-05 05:40 | Mathieu Westphal | Note Added: 0034511 | |
2015-06-08 18:48 | Alan Scott | Note Added: 0034520 | |
2015-06-08 18:48 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
