0015507 | ParaView | (No Category) | public | 2015-06-04 04:00 | 2015-07-10 20:41 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Dan Lipsa | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Target Version | 4.4 | Fixed in Version | |||||||
Summary | 0015507: Multiblock Inspector not working correctly | ||||||||
Description | (Using Matser git version 2015-06-02, bug present on 4.3.1 as well ) Mutliblock inspector display incorrect block name and does not allow to select/show the corrects blocks. How to reproduce : Open paraview Open test.vtm (see uploaded file) view->MultiBlock Inspector a. uncheck Block #1, recheck it b. uncheck Block #2, recheck it c. uncheck Block #1, recheck it What is observed : a. spheres disapear, then reappear b. spheres disapear, then reappear c. nothing happens What is expected : a. spheres disapear, then reappear b. cubes disapear, then reapear c. spheres disapear, then reappear Also the block labels should be Block #0 Block#1 instead of Block#1 Block #2 | ||||||||
Project | Sandia | ||||||||
Attached Files | test.tgz [^] (3,606 bytes) 2015-06-04 04:00 | ||||||||
(0034723) Dan Lipsa (developer) 2015-07-09 13:30 edited on: 2015-07-09 13:43 |
In ParaView, vtkPVCompositeDataInformation returns the flat_index for Block #2 as 2 (because it considers multi-piece datasets as leafs), in VTK vtkCompositePainter consider its flat_index as being 5 (because it descents in multi-piece datasets). Note that one can select individual pieces in a multi-piece dataset and also the code is there to set their color and opacity. vtkDataObjectTreeIterator does not now about multi-piece data so the flat_index would return would be 5. |
(0034737) Dan Lipsa (developer) 2015-07-10 09:48 |
commit e798ef0ce69e5e4d55b0883d76f8cac755eb0711 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Jul 9 18:26:26 2015 -0400 BUG 0015507: Multi-block inspector computed the flat index wrong. For a multi-block dataset containing multi-piece data, the flat index should be computed by traversing all data including the pieces in the multi-piece data. For instance for a multi-block containing 2 multi-piece datsets, each with three pieces, the index for the second multi-piece datset should be 5 not 2. |
(0034738) Utkarsh Ayachit (administrator) 2015-07-10 09:55 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/209 [^] |
(0034752) Alan Scott (manager) 2015-07-10 20:41 |
Tested master, Linux, remote server. |
2015-06-04 04:00 | Mathieu Westphal | New Issue | |
2015-06-04 04:00 | Mathieu Westphal | Assigned To | => Utkarsh Ayachit |
2015-06-04 04:00 | Mathieu Westphal | File Added: test.tgz | |
2015-06-04 11:59 | Utkarsh Ayachit | Target Version | => 4.4 |
2015-06-07 14:12 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
2015-06-07 14:12 | Utkarsh Ayachit | Status | backlog => todo |
2015-07-07 22:30 | Alan Scott | Project | TBD => Sandia |
2015-07-08 16:30 | Utkarsh Ayachit | Status | todo => backlog |
2015-07-08 16:36 | Utkarsh Ayachit | Status | backlog => todo |
2015-07-08 16:53 | Dan Lipsa | Status | todo => active development |
2015-07-08 23:15 | Dan Lipsa | Assigned To | => Dan Lipsa |
2015-07-09 13:30 | Dan Lipsa | Note Added: 0034723 | |
2015-07-09 13:33 | Dan Lipsa | Note Edited: 0034723 | |
2015-07-09 13:43 | Dan Lipsa | Note Edited: 0034723 | |
2015-07-10 09:48 | Dan Lipsa | Note Added: 0034737 | |
2015-07-10 09:55 | Utkarsh Ayachit | Note Added: 0034738 | |
2015-07-10 09:55 | Utkarsh Ayachit | Status | active development => customer review |
2015-07-10 09:55 | Utkarsh Ayachit | Resolution | open => fixed |
2015-07-10 20:41 | Alan Scott | Note Added: 0034752 | |
2015-07-10 20:41 | Alan Scott | Status | customer review => closed |
