0015534VTK(No Category)public2015-06-11 12:522016-07-06 11:19
Reporterdkuegler
Assigned ToSean McBride
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version6.0.0
Summary0015534: Visual Studio 2015 Compilation Errors
DescriptionHello,
I am trying to compile VTK 6.2.0 on Visual Studio 2015 RC.
I have made the following observations:
I get the following error:
Severity Code Description Project File Line
Error C2065 'timezone': undeclared identifier vtkhdf5 G:\Toolkits\VTK\VTK-6.2.0\ThirdParty\hdf5\vtkhdf5\src\H5Omtime.c 226
From \H5Omtime.c
#elif defined(H5_HAVE_TIMEZONE)
    /* Linux libc-5 */
    the_time -= timezone - (tm.tm_isdst?3600:0);
CMAKE defines in H5pubconf.h
/* Define if `timezone' is a global variable */
#define H5_HAVE_TIMEZONE 1
According to https://msdn.microsoft.com/en-us/library/htb3tdkc.aspx [^]
_get_timezone() should be used.
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
related to 0015535closed Visual Studio 2015 Compilation Errors
  Notes
(0034539)
dkuegler (reporter)
2015-06-11 14:49
H5_HAVE_TIMEZONE should not be defined. Instead lines 236 to 245 should be used, as HDgettimeofsay seems ti be bound to a Wgettimeofday, which gets defined in H5win32defs.h
so instead H5_HAVE_STRUCT_TIMEZONE, H5_HAVE_GETTIMEOFDAY and H5_GETTIMEOFDAY_GIVES_TZ should possibly be defined for Visual Studio 2015 RC.
(0034540)
dkuegler (reporter)
2015-06-11 15:32
For some reason timezone gets defined in time.h on line 275 for Visual Studio 2012, but not for Visual Studio 2015.
So I assume, H5_HAVE_TIMEZONE should have been undefined for Windows all along. Due to it being defined in time.h, it never caused any problems.
(0034689)
dkuegler (reporter)
2015-07-08 05:48
See https://gitlab.kitware.com/vtk/vtk/merge_requests/311 [^]
(0036176)
Sean McBride (developer)
2016-07-06 11:19
Looks like this was fixed by:
https://gitlab.kitware.com/vtk/vtk/merge_requests/446 [^]
Please reopen if still an issue.
 Issue History
2015-06-11 12:52 dkuegler New Issue
2015-06-11 14:49 dkuegler Note Added: 0034539
2015-06-11 15:32 dkuegler Note Added: 0034540
2015-07-08 05:48 dkuegler Note Added: 0034689
2015-08-28 08:28 T.J. Corona Relationship added related to 0015535
2016-07-06 11:19 Sean McBride Note Added: 0036176
2016-07-06 11:19 Sean McBride Status backlog => closed
2016-07-06 11:19 Sean McBride Assigned To => Sean McBride
2016-07-06 11:19 Sean McBride Resolution open => fixed
