0015559 | ParaView | (No Category) | public | 2015-07-01 11:17 | 2016-08-12 09:59 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Summary | 0015559: Setting color map range to [0, 1] has no effect | ||||||||
Description | Steps to reproduce: - launch paraview with built-in erver - Load disk_out_ref.ex2, all variables on - Click Rescale to custom range and set the range to [0, 1]. There is no change in the color legend The problem does not occur when setting the min to something other than zero or max to something other than 1. It occurs only when the range is set to [0, 1]. | ||||||||
Project | TBD | ||||||||
(0036675) Cory Quammen (developer) 2016-08-04 10:22 |
Tested ParaView 5.1, Mac OS, build-in server Launch ParaView Add Wavelet Change color to RTData Customize color bar range to [0, 1]. It works. |
(0038840) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-07-01 11:17 | Cory Quammen | New Issue | |
2016-08-04 10:22 | Cory Quammen | Note Added: 0036675 | |
2016-08-04 10:22 | Cory Quammen | Status | backlog => customer review |
2016-08-04 10:22 | Cory Quammen | Resolution | open => fixed |
2016-08-04 10:22 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038840 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
