0015585 | ParaView | (No Category) | public | 2015-07-16 06:13 | 2016-08-12 09:59 | ||||
Reporter | Pierluigi Cirrottola | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015585: error reading openFOAM case.foam using table driven variables | ||||||||
Description | sometime I use 'table' driven variables, in 0/ directory, both in U,p,k,epsilon files. Reading openFOAM results, I receive this error: ----------------------- ERROR: In /home/kitware/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6524 vtkOpenFOAMReaderPrivate (0x3ef65c0): Wrong list type for uniform field ----------------------- in this case for k end epsilon. In attached file there are two different cases: U is a variable vector, while k,epsilon are variable scalars. Thank for your attention, Bye Piero Cirrottola | ||||||||
Project | TBD | ||||||||
Attached Files | Paraview_bug.tar.gz [^] (1,882 bytes) 2015-07-16 06:13 | ||||||||
(0038845) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-07-16 06:13 | Pierluigi Cirrottola | New Issue | |
2015-07-16 06:13 | Pierluigi Cirrottola | File Added: Paraview_bug.tar.gz | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038845 | |
