0015655ParaView(No Category)public2015-08-15 17:222016-08-12 09:59
ReporterBruno Santos
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version4.3
Summary0015655: "ui_pqExportStateWizard.h" is always included with development install when it also depends on Python
DescriptionThe file "Qt/Components/CMakeLists.txt" has this block of code:
    if(PARAVIEW_INSTALL_DEVELOPMENT_FILES)
      install(FILES "${CMAKE_CURRENT_BINARY_DIR}/ui_pqExportStateWizard.h"
              DESTINATION "${VTK_INSTALL_INCLUDE_DIR}")
    endif()
And it should be this:
    if(PARAVIEW_INSTALL_DEVELOPMENT_FILES AND PARAVIEW_ENABLE_PYTHON)
    endif()
This is because of the block of code several lines above:
    if(PARAVIEW_ENABLE_PYTHON)
      LIST(APPEND Module_UI_FILES
        Resources/UI/pqImageOutputInfo.ui
        Resources/UI/pqExportStateWizard.ui
    endif()
This was spotted with the building script makeParaView4 that is used in OpenFOAM: https://github.com/OpenFOAM/ThirdParty-dev/#buiding-paraview-431 [^]
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0035213)
Louis Gagnon (reporter)
2015-09-14 08:43
I experienced the same issue and the fix proposed by Bruno Santos works for me.
(0038867)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2015-08-15 17:22 Bruno Santos New Issue
2015-09-14 08:43 Louis Gagnon Note Added: 0035213
2016-08-12 09:59 Kitware Robot Note Added: 0038867
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
