0015656 | ParaView | (No Category) | public | 2015-08-18 05:17 | 2016-08-12 09:59 | ||||
Reporter | Michaël Baudin | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015656: Plot Matrix View segfaults on text data | ||||||||
Description | The csv file in attachment contains text data. When I open the Plot Matrix View, Paraview segfaults. This bug happens both on Windows and Linux. (Actually, the data in attachment is only a part of the full data.) The first bug is that the code for the Plot Matrix View is not consistent with the Spread Sheet View : * the Spread Sheet View allows to display text and numerical data, * the Plot Matrix View only manages numerical data and fails on text. The second bug is that no exception is catched (e.g. "Unable to make plot."), which leads to a segfault. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | nba_ht_wt.dat - Texte.csv [^] (170 bytes) 2015-08-18 05:17 | ||||||||
(0038868) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-18 05:17 | Michaël Baudin | New Issue | |
2015-08-18 05:17 | Michaël Baudin | File Added: nba_ht_wt.dat - Texte.csv | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038868 | |
