0015676 | ParaView | (No Category) | public | 2015-08-25 03:57 | 2016-08-12 09:59 | ||||
Reporter | Christophe Bourcier | ||||||||
Summary | 0015676: In v4.4.0-RC1, deleting a source from the pipeline leads to segmentation fault | ||||||||
Description | 1. Load can.ex2 In the pipeline, right-click delete. gdb backtrace: Program received signal SIGSEGV, Segmentation fault. 0x00007f20e0070ed6 in vtkSMParaViewPipelineController::GetHelperProxyGroupName (proxy=<error reading variable: Cannot access memory at address 0x7fff49c43f70>) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:127 127 { 2. Create an arrow source In the pipeline, right-click delete. gdb backtrace: #1 0x00007f83f4a11049 in __dynamic_cast () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #2 0x00007f83f4a4f330 in bool std::has_facet<std::ctype<char> >(std::locale const&) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #3 0x00007f83f4a42fc4 in std::basic_ios<char, std::char_traits<char> >::_M_cache_locale(std::locale const&) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #4 0x00007f83f4a43130 in std::basic_ios<char, std::char_traits<char> >::init(std::basic_streambuf<char, std::char_traits<char> >*) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #5 0x00007f83f4a62b90 in std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #6 0x00007f83ffab1f21 in vtkSMParaViewPipelineController::GetHelperProxyGroupName (proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:129 #7 0x00007f83ffab69d6 in vtkSMParaViewPipelineController::FinalizeProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1133 #8 0x00007f83ffab55ea in vtkSMParaViewPipelineController::UnRegisterRepresentationProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:838 0000009 0x00007f83ffab7169 in vtkSMParaViewPipelineController::UnRegisterProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1239 #10 0x00007f83ffab6f87 in vtkSMParaViewPipelineController::UnRegisterDependencies (this=0x66542c0, proxy=0x5be8180) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1210 0000011 0x00007f83ffab6c3f in vtkSMParaViewPipelineController::FinalizeProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1157 #12 0x00007f83ffab55ea in vtkSMParaViewPipelineController::UnRegisterRepresentationProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:838 #13 0x00007f83ffab7169 in vtkSMParaViewPipelineController::UnRegisterProxy (this=0x66542c0, proxy=0x5be8290) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1239 #14 0x00007f83ffab6f87 in vtkSMParaViewPipelineController::UnRegisterDependencies (this=0x66542c0, proxy=0x5be8180) at /opt/ParaView/ParaView-git/ParaViewCore/ServerManager/Core/vtkSMParaViewPipelineController.cxx:1210 and so on. | ||||||||
Project | ParaViS | ||||||||
Type | crash | ||||||||
(0035175) Christophe Bourcier (reporter) 2015-09-07 04:10 |
This bug still exists in 4.4.0-RC2. |
(0035186) Christophe Bourcier (reporter) 2015-09-09 10:28 |
The bug appeared in 85ad847093a206a8b1b1b9018c69d8f0c71e628f Merge topic 'drop-vtksys-std-layer'. But it is not reproduced in: 3154b783090e58ee277d96a8d893d01ff9b796b1 Remove use of include <vtksys/ios/sstream> and vtksys_ios::*stringstream 34c0c40b1122e25d3b7920418babdc7ee8bd5bc0 Merge topic 'update_version_4.4.0-RC1' |
(0038874) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-25 03:57 | Christophe Bourcier | New Issue | |
2015-09-07 04:10 | Christophe Bourcier | Note Added: 0035175 | |
2015-09-09 10:28 | Christophe Bourcier | Note Added: 0035186 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038874 | |
