0015696 | ParaView | (No Category) | public | 2015-09-01 10:03 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Summary | 0015696: Selection not working correctly on the edge of a surface | ||||||||
Description | Some visible point cannot be selected using select on surface on the edge of a surface. | ||||||||
Steps To Reproduce | Open Paraview Create a sphere, apply click "Select on surface" Select the whole dataset Some points are not selected, even though they are visible | ||||||||
Additional Information | It looks like a problem when determining what point is visible are not. | ||||||||
Project | TBD | ||||||||
(0038881) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-09-01 10:03 | Mathieu Westphal | New Issue | |
2015-09-01 10:06 | Mathieu Westphal | Steps to Reproduce Updated | |
2015-09-01 10:06 | Mathieu Westphal | Additional Information Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038881 | |
