0015747 | ParaView | (No Category) | public | 2015-09-29 18:46 | 2015-12-15 20:20 | ||||
Reporter | Kai | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.4 | ||||||||
Target Version | Fixed in Version | 5.0 | |||||||
Summary | 0015747: ParaViewWeb - STL File Load Issue | ||||||||
Description | Pleased Find the attached Mitchell.stl ERROR: In /home/user/ParaViewWeb/ParaView/src/VTK/IO/Geometry/vtkSTLReader.cxx, line 461 vtkSTLReader (0x5d89b50): STLReader: error while reading file /home/user/ParaViewWeb/data/Mitchell.stl at line 14: unable to read reading point. ERROR: In /home/user/ParaViewWeb/ParaView/src/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x5d84f70): Algorithm vtkFileSeriesReader(0x5d881b0) returned failure for request: vtkInformation (0x5d97f30) Debug: Off Modified Time: 225417 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 | ||||||||
Project | Kitware | ||||||||
Type | crash | ||||||||
Attached Files | ![]() | ||||||||
(0035248) Joachim Pouderoux (developer) 2015-09-30 09:59 |
I loaded the file successfully with 4.3.1. With 4.4 it fails as mentioned. |
(0035249) Joachim Pouderoux (developer) 2015-09-30 10:02 |
Works with master - solved by https://gitlab.kitware.com/vtk/vtk/merge_requests/592 [^] |
(0035250) Cory Quammen (developer) 2015-09-30 10:23 |
Joachim, thanks for testing. That was the change I was concerned broke this. I confirm this is fixed in master. Other testing shows: ParaView 4.1.0 - succeeds ParaView 4.2.0 - succeeds ParaView 4.3.1 - fails ParaView 4.4.0 - fails ParaView master - succeeds |
(0035251) Cory Quammen (developer) 2015-09-30 10:24 |
Already fixed on master |
(0035565) Alan Scott (manager) 2015-12-15 20:20 |
Tested 5.0.0-RC2, Linux, remote server (8 processes) |
2015-09-29 18:46 | Kai | New Issue | |
2015-09-29 18:46 | Kai | Assigned To | => Cory Quammen |
2015-09-29 18:46 | Kai | File Added: Mitchell.stl | |
2015-09-29 19:00 | Kai | Summary | STL File Load Issue => ParaViewWeb - STL File Load Issue |
2015-09-30 09:59 | Joachim Pouderoux | Note Added: 0035248 | |
2015-09-30 10:02 | Joachim Pouderoux | Note Added: 0035249 | |
2015-09-30 10:23 | Cory Quammen | Note Added: 0035250 | |
2015-09-30 10:24 | Cory Quammen | Note Added: 0035251 | |
2015-09-30 10:24 | Cory Quammen | Status | backlog => gatekeeper review |
2015-09-30 10:24 | Cory Quammen | Fixed in Version | => git-master |
2015-09-30 10:24 | Cory Quammen | Resolution | open => no change required |
2015-10-28 09:29 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 |
2015-12-11 14:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-15 20:20 | Alan Scott | Note Added: 0035565 | |
2015-12-15 20:20 | Alan Scott | Status | customer review => closed |
