0015768ParaView(No Category)public2015-10-09 21:192016-08-12 09:59
ReporterAlan Scott
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version4.4
Summary0015768: Allow selecting of data fields in .vtm files.
DescriptionFrom the paraview.org list:
I noticed that when I load a .vtm file, I cannot select which data fields to load. This requires me to load the entire file into memory, after which the Pass Arrays filter allows me to take the required data field forward in the pipeline. If I load other formats (e.g. CGNS and .vtu) I can choose which field to load.
Maybe I’m missing something obvious? Should there be metadata on the fields in the vtm file that is missing?
TagsNo tags attached.
ProjectTBD
Topic Name
Typefeature
 Relationships
has duplicate 0015789closedKitware Robot Array selection on .vtm multi-block reader
  Notes
(0038904)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2015-10-09 21:19 Alan Scott New Issue
2015-10-19 10:01 Cory Quammen Relationship added has duplicate 0015789
2016-08-12 09:59 Kitware Robot Note Added: 0038904
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
