0015786 | ParaView | (No Category) | public | 2015-10-16 10:37 | 2016-08-12 09:59 | ||||
Reporter | Cory Quammen | ||||||||
Product Version | 4.4 | ||||||||
Summary | 0015786: QString.toDouble() does not parse locale-specific number strings | ||||||||
Description | Report from Gerald Lodron on the paraview mailing list. ------- I noticed a bug in paraview on parsing double values in QLineEdits, e.g. in pqDoubleEdit: double pqDoubleEdit::value() { QString currentText = this->text(); int currentPos = this->cursorPosition(); QDoubleValidator dvalidator(NULL); QValidator::State state = dvalidator.validate(currentText, currentPos); if (state == QValidator::Acceptable || state == QValidator::Intermediate) { return currentText.toDouble(); } return 0.0; } The Problem is that QDoubleValidator uses the current locale. If the current locale is e.g. German that e.g. “0.1” is not allowed, only “0,1”. On the other side the QString function toDouble cannot parse it correctly, see documentation http://doc.qt.io/qt-5/qstring.html#toDouble [^] , here the http://doc.qt.io/qt-5/qlocale.html#toDouble [^] is recommended…. So all QLineEdit functions with toDouble must be replaced by QLocale oL; Double dValue = oL.toDouble( lineEdit->text()) Nasty….Other solution would be to set the locale to English for whole paraview regardless to the system locale, but I don’t know if that is possible (also not very beautiful)… | ||||||||
Project | TBD | ||||||||
(0035314) Lodron Gerald (reporter) 2015-10-20 03:32 |
Other solution: Write an own subclass of QValidator with internal QString::toDouble() check for validity... |
(0038910) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-10-16 10:37 | Cory Quammen | New Issue | |
2015-10-20 03:32 | Lodron Gerald | Note Added: 0035314 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038910 | |
