0015810 | ParaView | (No Category) | public | 2015-10-25 12:21 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015810: Contour with annotated color | ||||||||
Description | Allow a user to color the different contours created by the contour add range of values filter. A good example of this is sources/ wavelet. Create contours on RTdata. Make 10 contours. If we set opacity to 40%, I want to see each contour by it's unique color. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0036335) Alan Scott (manager) 2016-07-09 12:41 |
I also want the ability to label each contour. |
(0038919) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-10-25 12:21 | Alan Scott | New Issue | |
2015-10-25 17:55 | Alan Scott | Target Version | => 5.1 |
2016-07-09 12:41 | Alan Scott | Note Added: 0036335 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038919 | |
