0015850 | ParaView | (No Category) | public | 2015-11-25 19:41 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015850: hdf5 file from PFLOTRAN Color by Material_ID doesn't work correctly. | ||||||||
Description | When you load an hdf5 file, ParaView fails to create and paint by a variable named Material_ID. Visit does paint this correctly (correctly defined here as what my customer wants and VisIt does). Here is how to replicate on VisIt: * Download, install VisIt. * Load file trial3.h5 (I will give this to Utkarsh). * Plots/ Add/ Fill Boundary/ Material_ID. * Draw. Now, notice that the bar is painted by material ID. This represents where each of the materials is 1 (i.e., positive result) (as opposed to -1, negative result). Now, run Paraview, and load trial3.h5. All variables on. Apply. Notice that you can't paint by Material_ID. What I want: * To expose, or create, Material_ID. Then, we need to color by Annotated Color, KAAMS color map. | ||||||||
Project | Sandia | ||||||||
(0035486) Alan Scott (manager) 2015-11-25 19:43 |
note to self, file is on PC, hdpark |
(0038937) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-11-25 19:41 | Alan Scott | New Issue | |
2015-11-25 19:43 | Alan Scott | Note Added: 0035486 | |
2015-11-25 19:44 | Alan Scott | Target Version | => 5.1 |
2015-11-25 19:45 | Alan Scott | Summary | hdf5 file, Color by Material_ID doesn't work correctly. => hdf5 file from PFLOTRAN Color by Material_ID doesn't work correctly. |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038937 | |
