0015864 | ParaView | (No Category) | public | 2015-12-04 20:39 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015864: Annotated color legend isn't hidden correctly for trace | ||||||||
Description | We are having strange behavior for the annotated color legend, where it appears when it shouldn't. I have found a trivial way to replicate it using the trace recorder. This may be a symptom of other issues, I cannot tell. * Windows, local server, 4.4.0. * Start trace. * Open can.exo. All vars on. Apply. * Clip. Apply. * Color by EQPS. * Stop trace. Save trace as macro. * Reset session. * Run macro. >> The Annotated color legend shows up, even though can is hidden. This is a bug. | ||||||||
Project | Sandia | ||||||||
(0035519) Utkarsh Ayachit (administrator) 2015-12-08 07:02 |
Marking as targeted for 5.0 but can slip to 5.1 if needed. |
(0038945) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-04 20:39 | Alan Scott | New Issue | |
2015-12-04 20:40 | Alan Scott | Target Version | => 5.1 |
2015-12-08 07:02 | Utkarsh Ayachit | Note Added: 0035519 | |
2015-12-08 07:02 | Utkarsh Ayachit | Target Version | 5.1 => 5.0 |
2016-01-08 15:31 | Utkarsh Ayachit | Target Version | 5.0 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038945 | |
