0015871 | ParaView | (No Category) | public | 2015-12-10 18:47 | 2016-07-22 19:28 | ||||
Reporter | Nico Schlömer | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0015871: libvtkIOXdmf3: undefined symbol: _ZN16XdmfSparseMatrix7setNameERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE | ||||||||
Description | I've had long-standing trouble doing `import vtk` when Xdmf3 is enabled. I'd usually get ``` >>> import vtk # [...] ImportError: No module named vtkIOXdmf3Python ``` To do some digging, I cd'd into `/usr/lib/python2.7/dist-packages/vtk` and imported vtkIOXdmf3Python: ``` python -c "import vtkIOXdmf3Python" Traceback (most recent call last): File "<string>", line 1, in <module> ImportError: /usr/lib/x86_64-linux-gnu/libvtkIOXdmf3-6.3.so.6.3: undefined symbol: _ZN16XdmfSparseMatrix7setNameERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE ``` | ||||||||
Tags | Hackathon-July-2016 | ||||||||
Project | TBD | ||||||||
(0036396) Dave DeMarle (administrator) 2016-07-13 14:52 |
Nico, Unfortunately I could not reproduce this bug on mac or linux with ParaView master with binaries, build trees or installs trees. From the message you report, it looks like libXdmfCore.so is not on the library search path for some reason. To track it down I need to know more about how your built and installed paraview, what platform you are on etc also, please try adding the path to libXdmf* from the ParaView build to your PATH manually and see if that resolves the error. Please reopen this bug if it is still an issue for you and add in more detail to help reproduce the bug. |
(0036552) Alan Scott (manager) 2016-07-22 19:28 |
Closing. As mentioned by Dave, please reopen with more detail if it is still an issue. |
2015-12-10 18:47 | Nico Schlömer | New Issue | |
2015-12-10 18:47 | Nico Schlömer | Description Updated | |
2016-07-12 11:48 | Utkarsh Ayachit | Tag Attached: Hackathon-July-2016 | |
2016-07-13 10:24 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-07-13 10:24 | Dave DeMarle | Status | backlog => active development |
2016-07-13 14:52 | Dave DeMarle | Note Added: 0036396 | |
2016-07-13 14:52 | Dave DeMarle | Status | active development => customer review |
2016-07-13 14:52 | Dave DeMarle | Resolution | open => fixed |
2016-07-22 19:28 | Alan Scott | Note Added: 0036552 | |
2016-07-22 19:28 | Alan Scott | Status | customer review => closed |
