0015872 | ParaView | (No Category) | public | 2015-12-11 04:17 | 2016-07-13 11:01 | ||||
Reporter | Nico Schlömer | ||||||||
Target Version | Fixed in Version | git-master | |||||||
Summary | 0015872: build failure with `-DVTK_MAKE_INSTANTIATORS=ON` | ||||||||
Description | Right now, master fails to build with ``` In file included from /«PKGBUILDDIR»/debian/build/Rendering/Annotation/vtkRenderingAnnotationInstantiator.cxx:12:0: /«PKGBUILDDIR»/Rendering/Annotation/vtkCubeAxesActor2D.h:49:29: error: expected identifier before numeric constant #define VTK_FLY_OUTER_EDGES 0 ``` I suppose that merge 04bf83baf617feaff606137ece6c4df106f9a198 is to blame. I can reproduce this with ``` cmake \ -DVTK_MAKE_INSTANTIATORS=ON \ ../../pristine/ ``` | ||||||||
Tags | Hackathon-July-2016 | ||||||||
Project | TBD | ||||||||
(0036354) Utkarsh Ayachit (administrator) 2016-07-13 11:01 |
VTK_MAKE_INSTANTIATORS is deprecated in VTK and ParaView does not support it. You should not need to use vtkInstantiator. ParaView provides vtkPVInstantiator that can be used for similar effect if needed. |
2015-12-11 04:17 | Nico Schlömer | New Issue | |
2015-12-12 09:34 | Nico Schlömer | Note Added: 0035551 | |
2015-12-12 09:34 | Nico Schlömer | Summary | error: expected identifier before numeric constant #define VTK_FLY_OUTER_EDGES 0 => build failure with `-DVTK_MAKE_INSTANTIATORS=ON` |
2015-12-12 09:34 | Nico Schlömer | Description Updated | |
2015-12-12 09:34 | Nico Schlömer | Note Deleted: 0035551 | |
2016-07-12 11:48 | Utkarsh Ayachit | Tag Attached: Hackathon-July-2016 | |
2016-07-13 11:01 | Utkarsh Ayachit | Note Added: 0036354 | |
2016-07-13 11:01 | Utkarsh Ayachit | Status | backlog => closed |
2016-07-13 11:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-07-13 11:01 | Utkarsh Ayachit | Resolution | open => won't fix |
2016-07-13 11:01 | Utkarsh Ayachit | Fixed in Version | => git-master |
