0015898 | ParaView | (No Category) | public | 2015-12-21 23:40 | 2016-02-24 18:58 | ||||
Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
Summary | 0015898: vtkSDDP::EXACT_EXTENT() logic needs to be revisited | ||||||||
Description | In vtkSDDP::ProcessRequest(), EXACT_EXTENT() is checked after RequestData() is called on an algorithm if a down-stream filter requests EXTACT_EXTENT(). However, after the filter has executed, if a new filter is added downstream that doesn't change the update request except adding EXTACT_EXTENT(), then since the upstream pipeline doesn't reexecute, it never does the EXACT_EXTENT() check and hence never crops the data. This causes the following issue when connected to at least 2 rank pvserver: + Wavelet, Apply + Contour (ensure Compute Normals is checked), Apply + Now, go back o the Wavelet and render it as "Volume". It will not render correctly. + Now change origin on the Wavelet to modify it. Apply. Things now work as expected. | ||||||||
Project | TBD | ||||||||
Relationships | ||||||
(0035631) Utkarsh Ayachit (administrator) 2016-01-05 16:55 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/556 [^] |
(0035787) Alan Scott (manager) 2016-02-24 18:58 |
Tested with Utkarsh's excellent directions Linux, master, 8 remote ranks. |
2015-12-21 23:40 | Utkarsh Ayachit | New Issue | |
2015-12-21 23:40 | Utkarsh Ayachit | Assigned To | => Berk Geveci |
2015-12-22 00:00 | Utkarsh Ayachit | Relationship added | related to 0015900 |
2016-01-05 16:55 | Utkarsh Ayachit | Note Added: 0035631 | |
2016-01-05 16:55 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2016-01-05 16:55 | Utkarsh Ayachit | Resolution | open => fixed |
2016-01-05 16:55 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2016-01-06 13:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-01-06 13:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
2016-01-08 15:31 | Utkarsh Ayachit | Target Version | => 5.0 |
2016-01-08 15:32 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 |
2016-02-24 18:58 | Alan Scott | Note Added: 0035787 | |
2016-02-24 18:58 | Alan Scott | Status | customer review => closed |
