0015902 | ParaView | (No Category) | public | 2015-12-22 17:20 | 2016-07-25 21:56 | ||||
Assigned To | T.J. Corona | ||||||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015902: Threshold failing for particles | ||||||||
Description | I am including a dataset of particle data. It has three variables, temperature, pizzas and vectors. Pizza goes from 0 to 4. Everything is 0, except there is one 1, one 2 one 3 and one 4. Threshold fails on pizza. This needs to be fixed. Open file sampleUnstructuredGridParticles.vtk. All vars on, apply. Threshold on Pizza, from 0.5 to 4. No particles pass through this filter, but should. Windows, local server, 4.4.0. | ||||||||
Project | Sandia | ||||||||
Attached Files | sampleUnstructuredGridParticles.vtk [^] (16,444 bytes) 2015-12-22 17:20 | ||||||||
(0036099) T.J. Corona (developer) 2016-06-23 15:12 |
The problem is not with ParaView, but with your dataset. It describes 52 cells: 51 cells have 10 points associated with them, and 1 has 2 points. The CELL_TYPES array identifies these cells as vertices (cell type 1), however, rather than poly-vertices (cell type 2). If you change this array to contain 2s, then the behavior is as you would expect (if "All Scalars" is selected, none of the cells pass because each cell has a point with pizza value 0; if "All Scalars" is not selected, the filter returns the cells that have the nonzero pizza values). |
(0036583) Alan Scott (manager) 2016-07-25 21:56 |
Correct, good catch! Closing bug. |
2015-12-22 17:20 | Alan Scott | New Issue | |
2015-12-22 17:20 | Alan Scott | File Added: sampleUnstructuredGridParticles.vtk | |
2015-12-22 17:21 | Alan Scott | Target Version | => 5.1 |
2016-06-23 15:08 | T.J. Corona | Assigned To | => T.J. Corona |
2016-06-23 15:12 | T.J. Corona | Note Added: 0036099 | |
2016-06-23 15:12 | T.J. Corona | Status | backlog => gatekeeper review |
2016-06-23 15:12 | T.J. Corona | Resolution | open => fixed |
2016-07-12 17:17 | T.J. Corona | Status | gatekeeper review => customer review |
2016-07-12 17:17 | T.J. Corona | Resolution | fixed => no change required |
2016-07-25 21:56 | Alan Scott | Note Added: 0036583 | |
2016-07-25 21:56 | Alan Scott | Status | customer review => closed |
