0015954 | ParaView | (No Category) | public | 2016-01-21 16:27 | 2016-06-09 10:58 | ||||
Assigned To | Cory Quammen | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | 5.1 | ||||||
Summary | 0015954: Example visualizations | ||||||||
Description | Create a dialog box with links to the following state files. Must run from behind a firewall. Add verbiage to this dialog box explaining the commands that are in the dataset. (Ask me, Ken or Utkarsh if this sounds like a bad idea, lets discuss). (Also, ask one of us if these examples appear too complex.) * Load can.exo. All variables loaded. Clip. Select Can.exo again, clip again. Inside out. Go to timestep 10. Now, color by EQPS. Rescale to data range. * Load disk_out_ref.exo. All variables loaded. Clip. Turn off plane. Apply. Paint by Temp. Select disk_out_ref.exo. Stream Tracer. Apply. Tube filter. Apply. Paint by Pres. Select Stream Tracer. Glyph. Vectors == V. Scale Mode == vector. Reset scale factor. Apply. * Shuttle, showing a fluid dynamics viz * An Eularian demo. (Note, I'll finish writing this up later). Note - Data Set Sizes: can.ex2 - 17 MB disk_out_ref.exo - 1 MB shuttle (body, sslv) - 30 MB | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
Attached Files | ExampleVisualizations.png [^] (112,780 bytes) 2016-05-11 00:30
Relationships | ||||||
(0035915) Cory Quammen (developer) 2016-04-26 13:01 |
30MB for the shuttle data set would be a lot to add to the installer. 17MB for can is probably okay, especially considering it will be referenced in the quick start guide. Could we supply a couple of smaller example data sets in the installer for the folks not connected to the internet and some optional larger data sets for those who can download? |
(0035916) Alan Scott (manager) 2016-04-26 18:45 |
I agree - we want to balance presenting useful datasets with keeping tarball size small. Please feel free to use your discretion. As you say, Shuttle may be too big to bundle with PV - either delete it from this request, or feel free to substitute something smaller. |
(0035919) Cory Quammen (developer) 2016-04-29 09:47 |
Alan, let's start with the two smaller data sets. We can add more in future versions as desired. |
(0035920) Alan Scott (manager) 2016-04-29 13:42 |
Agreed. |
(0035946) Cory Quammen (developer) 2016-05-11 00:31 |
I uploaded the current dialog box linking to example visualizations. |
(0035949) Alan Scott (manager) 2016-05-12 15:47 |
Nice. |
(0036027) Utkarsh Ayachit (administrator) 2016-05-30 09:34 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/796#note_110178 [^] |
(0036030) Alan Scott (manager) 2016-05-31 17:48 |
Tested Linux, master, local server. Spectacular. |
2016-01-21 16:27 | Alan Scott | New Issue | |
2016-01-21 16:49 | Alan Scott | Relationship added | related to 0015952 |
2016-01-21 16:53 | Alan Scott | Target Version | => 5.1 |
2016-04-26 12:58 | Cory Quammen | Assigned To | => Cory Quammen |
2016-04-26 12:58 | Cory Quammen | Status | backlog => active development |
2016-04-26 13:01 | Cory Quammen | Note Added: 0035915 | |
2016-04-26 18:45 | Alan Scott | Note Added: 0035916 | |
2016-04-29 09:47 | Cory Quammen | Note Added: 0035919 | |
2016-04-29 13:42 | Alan Scott | Note Added: 0035920 | |
2016-05-11 00:30 | Cory Quammen | File Added: ExampleVisualizations.png | |
2016-05-11 00:31 | Cory Quammen | Note Added: 0035946 | |
2016-05-12 15:47 | Alan Scott | Note Added: 0035949 | |
2016-05-30 09:34 | Utkarsh Ayachit | Note Added: 0036027 | |
2016-05-30 09:34 | Utkarsh Ayachit | Status | active development => customer review |
2016-05-30 09:34 | Utkarsh Ayachit | Fixed in Version | => git-master |
2016-05-30 09:34 | Utkarsh Ayachit | Resolution | open => fixed |
2016-05-31 17:48 | Alan Scott | Note Added: 0036030 | |
2016-05-31 17:48 | Alan Scott | Status | customer review => closed |
2016-06-09 10:58 | Utkarsh Ayachit | Fixed in Version | git-master => 5.1 |
