| 0015959 | ParaView | Bug | public | 2016-01-27 07:56 | 2016-08-12 10:00 | ||||
| Reporter | thorenz | ||||||||
| Priority | high | Severity | crash | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 5.0 | ||||||||
| Summary | 0015959: Paraview crashes often with StarCCM+-datasets | ||||||||
| Description | Hi, I observed lots of crashes when using datasets which were exported from StarCCM+ to Ensight file format. I managed to construct a simple case where it always happens to me. To reproduce: - Extract zip-file - load case-file - generate "Slice" with origin (0 0 115) and normal (0 0 1) - APPLY! I think it happens because the slice intersects exactly the nodes of the mesh. I tried Paraview versions 3.10, 3.98, 4.3.1 and 5.0.0: All the same. Best and thanks for your efforts, Carsten | ||||||||
| Project | Release | ||||||||
| Topic Name | |||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038985) Kitware Robot (administrator) 2016-08-12 10:00 |
| Notes |
| Issue History | |||
| 2016-01-27 07:56 | thorenz | New Issue | |
| 2016-01-27 07:56 | thorenz | File Added: starccm.zip | |
| 2016-01-27 09:26 | thorenz | Severity | minor => crash |
| 2016-01-27 09:26 | thorenz | Reproducibility | have not tried => always |
| 2016-01-27 09:26 | thorenz | Category | (No Category) => Bug |
| 2016-01-27 09:26 | thorenz | Description Updated | |
| 2016-02-11 11:48 | thorenz | Assigned To | => Utkarsh Ayachit |
| 2016-08-12 10:00 | Kitware Robot | Note Added: 0038985 | |
| 2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
| Issue History |
