0015975ParaView(No Category)public2016-02-05 09:462016-08-12 10:00
ReporterFelipe Bordeu
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version5.0
Summary0015975: Problem with save state in python format (missing apply opacity to objects)
DescriptionI found a bug in the latest verison 5.0.0 home compilation in linux (and binary versoiin from Web for windows)
to replicate:
- create a Wavelet source
- change to Volume representation
- change the opacity transfert function
- File-> Save State -> in python format -> use default ("any *modified* properties" and "Skip Hiden..." checked) (I tested with all 4 conbination of this options)
- Edit -> Reset Session
- Tools-> Python Shell -> Run Script (run the just created state in python)
The opacity is not applyed
in the attached file the output of the Save stated with the extra line to make things work.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
Attached Files? file icon test.py [^] (3,017 bytes) 2016-02-05 09:46
 Relationships
  Notes
(0038992)
Kitware Robot (administrator)
2016-08-12 10:00
Resolving issue as `moved`.
 Issue History
2016-02-05 09:46 Felipe Bordeu New Issue
2016-02-05 09:46 Felipe Bordeu File Added: test.py
2016-08-12 10:00 Kitware Robot Note Added: 0038992
2016-08-12 10:00 Kitware Robot Status backlog => closed
2016-08-12 10:00 Kitware Robot Resolution open => moved
2016-08-12 10:00 Kitware Robot Assigned To => Kitware Robot
