View Issue Details [ Jump to Notes ] | [ Print ] |
0015982 | ParaView | (No Category) | public | 2016-02-07 01:28 | 2016-08-12 10:00 |
Reporter | Ken Moreland | |
Assigned To | Kitware Robot | |
Status | closed | Resolution | moved | |
Product Version | 4.4 | |
Target Version | | Fixed in Version | | |
Summary | 0015982: Probe filter not working with dataset with voxels |
Description | The probe filter is not working with the attached dataset. I suspect it is related to the fact that this data set is an unstructured grid containing voxel cells (as opposed to hexahedral cells). To replicate, do the following.
1. Open the attached data set. Apply.
2. Add the probe filter. Apply.
Note that all the fields in the probe filter are listed as 0 even though that is not even in the range of many of the fields in the attached data set. |
Tags | No tags attached. |
Project | TBD |
Topic Name | |
Type | incorrect functionality |
Attached Files | scalars.vtu [^] (1,322,187 bytes) 2016-02-07 01:28 |
