0015986 | ParaView | (No Category) | public | 2016-02-10 03:37 | 2016-08-12 10:00 | ||||
Reporter | Mathieu Westphal | ||||||||
Summary | 0015986: Partial Array in multiblock data are not selectable in a Line Chart View | ||||||||
Description | It appears that, when comparing data from multiple blocks in a Line Chart View, the only selectionnable array in the "Series Parameters" widget are the non partials ones at root, yet duplicated for each block. Nothing prevent for displaying and comparing data which are not both blocks, it is even possible to do it by selecting the series for each block idenpendantly before displaying both. | ||||||||
Steps To Reproduce | Open Paraview Open PartialBug0.csv Open PartialBug0.csv Open PartialBug1.csv Group all threee table using a GroupDataSets filter Display it in a line chart view (Ignore the second block, it is here only to circonvene another bug : http://www.vtk.org/Bug/view.php?id=15945 [^] ) Display only the first block, all series appear Display only the third block, all series appear Display both first and third block, only non-partial array at root level appears. | ||||||||
Tags | Hackathon-July-2016 | ||||||||
Project | TBD | ||||||||
Attached Files | partialBug0.csv [^] (92,966 bytes) 2016-02-10 03:37 partialBug1.csv [^] (43,373 bytes) 2016-02-10 03:38 | ||||||||
Relationships | ||||||
(0038997) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-02-10 03:37 | Mathieu Westphal | New Issue | |
2016-02-10 03:37 | Mathieu Westphal | File Added: partialBug0.csv | |
2016-02-10 03:38 | Mathieu Westphal | File Added: partialBug1.csv | |
2016-02-10 03:41 | Mathieu Westphal | Steps to Reproduce Updated | |
2016-02-10 03:42 | Mathieu Westphal | Relationship added | related to 0015945 |
2016-07-12 11:38 | Utkarsh Ayachit | Tag Attached: Hackathon-July-2016 | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0038997 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
