0015994 | ParaView | (No Category) | public | 2016-02-11 21:54 | 2016-05-17 17:13 | ||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | 5.0.1 | ||||||
Summary | 0015994: Move Show Axis functionality into Edit Axes Grid. | ||||||||
Description | We need to get rid of the Show Axis, Cube Axes code, and implement the functionality of this deleted code into the Edit Axes Grid (i.e., new code). The main functionality we want is to allow the user to place the axis grid on the front of the dataset, along with present functionality that goes behind. | ||||||||
Project | Sandia | ||||||||
(0035825) Utkarsh Ayachit (administrator) 2016-03-07 13:08 |
> The main functionality we want is to allow the user to place the axis grid on the front of the dataset, along with present functionality that goes behind. Alan, this is already possible. In the "Edit Axes Grid" uncheck the "Cull Frontface" and instead check the "Cull Backface". You can also uncheck "Label Unique Edges only" if you want the shared edge in front of the camera labelled. |
(0035896) Alan Scott (manager) 2016-04-15 23:00 |
You are right! I have a few modifications, but will put them into a different bug. Mind getting rid of the Show Axis/ Grid Axis deprecated functionality on this bug? Tested master, Linux, local server. |
(0035924) Utkarsh Ayachit (administrator) 2016-05-02 16:53 |
Here's the MR to remove the cube axes: https://gitlab.kitware.com/paraview/paraview/merge_requests/755 [^] |
(0035926) Utkarsh Ayachit (administrator) 2016-05-03 22:25 |
Cube axes is no longer available in ParaView. |
(0035976) Alan Scott (manager) 2016-05-17 17:13 |
As per my previous testing (see above), closing. Further, Show Axes has been deleted as requested. Closing. |
2016-02-11 21:54 | Alan Scott | New Issue | |
2016-02-11 21:54 | Alan Scott | Target Version | => 5.1 |
2016-03-07 13:08 | Utkarsh Ayachit | Note Added: 0035825 | |
2016-03-07 13:08 | Utkarsh Ayachit | Status | backlog => customer review |
2016-03-07 13:08 | Utkarsh Ayachit | Fixed in Version | => 5.0.1 |
2016-03-07 13:08 | Utkarsh Ayachit | Resolution | open => fixed |
2016-03-07 13:08 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-04-15 23:00 | Alan Scott | Note Added: 0035896 | |
2016-04-15 23:00 | Alan Scott | Status | customer review => todo |
2016-05-02 16:53 | Utkarsh Ayachit | Note Added: 0035924 | |
2016-05-02 16:53 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2016-05-03 22:25 | Utkarsh Ayachit | Note Added: 0035926 | |
2016-05-03 22:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-05-17 17:13 | Alan Scott | Note Added: 0035976 | |
2016-05-17 17:13 | Alan Scott | Status | customer review => closed |
