0016001 | VTK | (No Category) | public | 2016-02-16 11:42 | 2016-07-06 10:41 | ||||
Reporter | Morgulis | ||||||||
Target Version | Fixed in Version | 7.1.0 | |||||||
Summary | 0016001: VTK fails to compile with FFmpeg 3.0 | ||||||||
Description | ffmpeg 3.0 has recently been released. I am trying to compile VTK 7 and it fails. Here is compilation error: [10043/22348] Building CXX object IO/FFMPEG/CMakeFiles/vtkIOFFMPEG.dir/vtkFFMPEGWriter.cxx.o [10044/22348] Tcl Wrapping - generating vtkOggTheoraWriterTcl.cxx [10045/22348] Building CXX object IO/Movie/CMakeFiles/vtkIOMovieTCL.dir/vtkIOMovieTCLInit.cxx.o FAILED: /usr/bin/c++ -DVTK_IN_VTK -DvtkIOFFMPEG_EXPORTS -D__STDC_CONSTANT_MACROS -IIO/Movie -I/build/vtk/src/VTK-7.0.0/IO/Movie -ICommon/DataModel -I/build/vtk/src/VTK-7.0.0/Common/DataModel -ICommon/Math -I/build/vtk/src/VTK-7.0.0/Common/Math -ICommon/Core -I/build/vtk/src/VTK-7.0.0/Common/Core -IUtilities/KWSys -I/build/vtk/src/VTK-7.0.0/Utilities/KWSys -ICommon/Misc -I/build/vtk/src/VTK-7.0.0/Common/Misc -ICommon/System -I/build/vtk/src/VTK-7.0.0/Common/System -ICommon/Transforms -I/build/vtk/src/VTK-7.0.0/Common/Transforms -ICommon/ExecutionModel -I/build/vtk/src/VTK-7.0.0/Common/ExecutionModel -IIO/Core -I/build/vtk/src/VTK-7.0.0/IO/Core -IThirdParty/zlib -I/build/vtk/src/VTK-7.0.0/ThirdParty/zlib -IThirdParty/oggtheora -I/build/vtk/src/VTK-7.0.0/ThirdParty/oggtheora -IIO/FFMPEG -I/build/vtk/src/VTK-7.0.0/IO/FFMPEG -D__STDC_CONSTANT_MACROS -O3 -DNDEBUG -fPIC -fvisibility=hidden -fvisibility-inlines-hidden -MMD -MT IO/FFMPEG/CMakeFiles/vtkIOFFMPEG.dir/vtkFFMPEGWriter.cxx.o -MF IO/FFMPEG/CMakeFiles/vtkIOFFMPEG.dir/vtkFFMPEGWriter.cxx.o.d -o IO/FFMPEG/CMakeFiles/vtkIOFFMPEG.dir/vtkFFMPEGWriter.cxx.o -c /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx: In member function 'int vtkFFMPEGWriterInternal::Start()': /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:194:18: error: 'PIX_FMT_YUVJ422P' was not declared in this scope c->pix_fmt = PIX_FMT_YUVJ422P; ^ /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:198:18: error: 'PIX_FMT_BGR24' was not declared in this scope c->pix_fmt = PIX_FMT_BGR24; ^ /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:277:40: error: 'avcodec_alloc_frame' was not declared in this scope this->rgbInput = avcodec_alloc_frame(); ^ /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:283:36: error: 'PIX_FMT_RGB24' was not declared in this scope int RGBsize = avpicture_get_size(PIX_FMT_RGB24, c->width, c->height); ^ /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx: In member function 'int vtkFFMPEGWriterInternal::Write(vtkImageData*)': /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:357:28: error: 'PIX_FMT_RGB24' was not declared in this scope cc->width, cc->height, PIX_FMT_RGB24, ^ /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx: In member function 'int vtkFFMPEGWriterInternal::Start()': /build/vtk/src/VTK-7.0.0/IO/FFMPEG/vtkFFMPEGWriter.cxx:326:53: warning: ignoring return value of 'int avformat_write_header(AVFormatContext*, AVDictionary**)', declared with attribute warn_unused_result [-Wunused-result] avformat_write_header(this->avFormatContext, NULL); ^ ninja: build stopped: subcommand failed. | ||||||||
Project | TBD | ||||||||
Attached Files | ffmpeg3_compat.patch [^] (2,347 bytes) 2016-02-17 17:12 [Show Content] | ||||||||
(0035748) Morgulis (reporter) 2016-02-17 17:12 |
Given patch makes ffmpeg3.0 compile errors go away. |
(0036163) Utkarsh Ayachit (administrator) 2016-07-06 10:40 |
Fixed by https://gitlab.kitware.com/vtk/vtk/commit/ffb53e9b53099cac99b8d0e6021d5a476b9ecf12 [^] |
2016-02-16 11:42 | Morgulis | New Issue | |
2016-02-17 17:12 | Morgulis | Note Added: 0035748 | |
2016-02-17 17:12 | Morgulis | File Added: ffmpeg3_compat.patch | |
2016-07-06 10:23 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-07-06 10:40 | Utkarsh Ayachit | Note Added: 0036163 | |
2016-07-06 10:41 | Utkarsh Ayachit | Status | backlog => closed |
2016-07-06 10:41 | Utkarsh Ayachit | Resolution | open => fixed |
2016-07-06 10:41 | Utkarsh Ayachit | Fixed in Version | => 7.1.0 |
