0016012 | ParaView | (No Category) | public | 2016-02-24 18:46 | 2016-08-12 10:00 | ||||
Target Version | 5.0.1 | Fixed in Version | |||||||
Summary | 0016012: Error message bindTexture | ||||||||
Description | We are seeing an error message that once it appears, it never stops appearing again. Note that it is possible this is a bad build on my part. * Debug build, remote server (8 processes, I bet can be replicated with fewer), master, Linux. * I blew away my .config files. -dr should do the same thing. * Edit/ Settings/ Render/ Remote Render Threshold to 0. OK. * Sources/ Wavelet. Apply. Representation: Surface. Color by: RTData. * Change Opacity to 0.5 on the Properties tab. * Open the Color Map Editor. The following errors occur, and keep popping on top of ParaView. ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkOpenGLTexture.cxx, line 233 vtkOpenGLTexture (0x3c10cf0): failed at glGetIntegerv 1 OpenGL errors detected 0 : (1282) Invalid operation ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkOpenGLActor.cxx, line 91 vtkOpenGLActor (0x33e0f70): failed after Render 1 OpenGL errors detected 0 : (1282) Invalid operation ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkTextureObject.cxx, line 540 vtkTextureObject (0x3b99350): failed at glBindTexture 1 OpenGL errors detected 0 : (1282) Invalid operation ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkOpenGLActor.cxx, line 91 vtkOpenGLActor (0x33e0f70): failed after Render 1 OpenGL errors detected 0 : (1282) Invalid operation | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0039006) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-02-24 18:46 | Alan Scott | New Issue | |
2016-02-24 18:48 | Alan Scott | Target Version | => 5.0.1 |
2016-04-15 21:42 | Alan Scott | Relationship added | related to 0016076 |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039006 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
