0016028 | ParaView | (No Category) | public | 2016-03-14 22:04 | 2016-08-12 10:00 | ||||
Product Version | 5.0 | ||||||||
Summary | 0016028: Option to have sidesets and edgesets be displayed on standard properties tab | ||||||||
Description | Please add the option, set off by default, to allow a user to display sidesets and edgesets on the standard properties tab. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0035840) Ken Moreland (manager) 2016-03-15 11:18 |
Maybe this is obvious to others, but can elaborate on what the expected behavior is? I'm guessing you mean side sets and edge sets from Exodus files. Sets in Exodus files are loaded as separate blocks in a multiblock dataset. Are you saying you want the equivalent of what is in the Multi-block inspector to be in the standard properties tab show you can turn blocks on and off, or are you saying that you want special code in ParaView to recognize the blocks the Exodus reader creates and handle them specially? |
(0039014) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-14 22:04 | Alan Scott | New Issue | |
2016-03-15 11:18 | Ken Moreland | Note Added: 0035840 | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039014 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
